I'm putting my computer together. The holes in Asrock Xtreme4 motherboard don't seem to match with Corsair 200R case; there are more standoffs than holes in the mobo. I was confident in research that they fit though. Help! Thanks.
There are several asrock boards that carry the extreme4 branding in both micro atx and atx form factors. Both form factors are supported by the case, but you have to adjust the standoffs accordingly.
The answer to all riddles, and I want to thank you guys for your input, is that the asrock extreme4 is indeed smaller than I thought, so some of the unremovable standoffs don't touch it. I had to remove one of the removable standoffs, and it fit!
