NZXT Havik 140 vs Thermaltake water 2.0 Performer
Hello,
About to start my second build and I am wondering what cooler would be the best for a 3570k.
I plan to overclock but only a little bit say .3 ghz.
My case is a antec nine hundred two v3
Thanks
6 answers Last reply
More about nzxt havik thermaltake water performer
  1. Coolermaster hyper 212 evo. Very good cooler and will serve your needs perfectly.
  2. Will this be better than the havik or the performer? Which one is better between the two listed? Thanks
  3. i will definitely go for the havick , i think its now available around $70~$75 and you can just add more 5 bucks and get a high end twin tower air cooler like the noctua nh-d14.
  4. ok thanks so you wouldn't recommend the performer? where i live they both cost the same price. and the noctua would not fit above my Ripjaws X Ram
  5. http://assets.overclock.net.s3.amazonaws.com/0/09/09a6507a_vbattach215673.jpeg
    http://imageshack.us/a/img543/6743/kzeqvl.jpg
    anyway the havik is better than the performer , and if you saw this pictures you may change your mind and get the noctua
  6. Getting the CPU OCed to 4.2GHz is pretty dam easy with a hyper 212 evo.
    i am in favor of one of these Coolers though
    http://pcpartpicker.com/part/noctua-cpu-cooler-nhu12pse2
    pretty big though
    or
    http://pcpartpicker.com/part/xigmatek-cpu-cooler-darkknightiisd1283nighthawkedition
    more in favor of this one and adding a second fan on it
New Build Thermaltake Systems
