I have a problem with my hpcompaq i was just remove bluetooth icon on taskbar
hei my friend my is Luyinda Z i have mini computer hpcomac but the bluetooth is not working but it was working at first whe i was looking some thing I just remove the bluetoot taskbar icon it's stoped to work now there are no drivers
but idont want to insitall windows agen
2 answers Last reply
More about problem hpcompaq remove bluetooth icon taskbar
  1. You never have to re-install windows. Just go to device manager at the menu bar click action and click scan for hardware changes. That will pick up your bluetooth device and will install drivers automatically for you.
    If that doesnt do it, make sure that its not "disabled" from device manager.
    Make sure the you have switched on the bluetooth device.
  2. Type "bluetooth settings" in the search box and get your bluetooth icon back.
    If driver is removed, do as flowingbass says and install driver from the company that makes your computer.
Drivers Taskbar Computers Bluetooth Windows 7
