Solved
About to buy parts - Am I good to go?
This is my budget gaming PC i'm going to build to play games like Planetside 2, Guild Wars 2, and Battlefield 3 at low-medium settings.
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Microcenter)
Motherboard: ASRock 970DE3/U3S3 ATX AM3+ Motherboard ($19.99 @ Microcenter)
Memory: Crucial 4GB (2 x 2GB) DDR3-1333 Memory ($25.99 @ Microcenter)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($56.99 @ Microcenter)
Video Card: MSI Radeon HD 7770 1GB Video Card ($114.99 @ Microcenter)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case ($44.99 @ Microcenter)
Power Supply: Corsair Builder Series CX430 430 Watt ATX 12V Power Supply ($54.99 @ Microcenter)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.99 @ Microcenter)
Total: $440.92
(Generated by PCPartPicker 2013-02-07 18:07 EST-0500)
CPU and Motherboard are in a bundle from microcenter.
Since I have an old copy of Windows XP sitting around, i'll install that and then upgrade to Windows 8. Also, i'll be using an HP 21 inch 1600x900 monitor.
10 answers Last reply Best Answer
More about about parts good
  1. Best answer
    Thats an amazing price
    The power supply is a weak point . Use only 80+ bronze or better rated units
    http://www.microcenter.com/product/399979/Builder_Series_CX430_430_Watt_ATX_12V_Power_Supply
    Much cheaper at newegg , usually
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    The motherboard too could be a problem . Despite the name it actually uses an older 770 chipset .
    Ideally find a board for just a few $ more that uses a 970 series chiipset. Probably
    http://www.microcenter.com/product/382894/970_Extreme3_Socket_AM3_970_ATX_AMD_Motherboard
    from the microcenter choices
    Hmm, ok.
    How about the Corsair CX Series CX500M 500 Watt ATX Modular Power Supply for $50 @ Microcenter? It's 80+ Bronze Certified.
    http://www.microcenter.com/single_product_results.aspx?sku=189811
    Ok, just saw the motherboard suggestion. That motherboard you linked doesn't come with a CPU bundle, so I don't think that would fit in with my budget.
    I was looking at the MSI 970A-G46 AM3+ ATX AMD Motherboard, but there are no in stock at the store I go to. :/
    Do you really think the current mobo could be a problem?
    Video Card: MSI Radeon HD 7770 1GB Video Card ($121.99 @ Microcenter)
    Power Supply: Antec 450W ATX12V Power Supply ($39.99 @ Microcenter)
    Total: $447.92
    Whats your max budget?
    CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
    Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($69.99 @ Newegg)
    Memory: Crucial Ballistix sport 4GB (1 x 4GB) DDR3-1600 Memory ($23.20 @ Amazon)
    Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($49.98 @ Outlet PC)
    Video Card: MSI GeForce GTX 650 Ti 1GB Video Card ($109.99 @ Newegg)
    Case: Cooler Master Elite 430 ATX Mid Tower Case ($39.99 @ Newegg)
    Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($24.99 @ Newegg)
    Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($18.98 @ Outlet PC)
    Total: $487.11
    (Generated by PCPartPicker 2013-02-07 19:52 EST-0500)
    For just $40 more... Better processor, ram, hard drive, and gpu for those games.
    Total: $487.11
    Hmm, that's very intriguing! Let me do some more looking around and i'll get back to you.. And my budget is anywhere between $450-$480.
    Total: $487.11
    Ok, well, I tried to make something out of that build but it doesn't fit in my budget if I buy from newegg/Microcenter..
    The total of mine was about $552 including shipping and tax.
  7. Any other suggestions?
  8. Alright, looks like i'm locked in to buy the parts this weekend.
  9. Best answer selected by MTSe7en.
New Build Systems Product
