B blade2697 Distinguished Jan 19, 2013 271 0 18,780 Feb 8, 2013 #1 As the title says. Which is better? Barebones kit? or Seperate parts?
Solution austing Feb 8, 2013 blade2697 : As the title says. Which is better? Barebones kit? or Seperate parts? Seperate parts gives you better components, but at a higher pricetag. Barebones kits give you great value on low-end parts, just enough to get by usually.
austing Honorable Jul 10, 2012 825 0 11,060 Feb 8, 2013 Solution #2 blade2697 : As the title says. Which is better? Barebones kit? or Seperate parts? Seperate parts gives you better components, but at a higher pricetag. Barebones kits give you great value on low-end parts, just enough to get by usually. Upvote 0 Downvote Solution
B blade2697 Distinguished Jan 19, 2013 271 0 18,780 Feb 9, 2013 #4 Best answer selected by blade2697. Upvote 0 Downvote
