Making ethernet wireless
i have problem about ethernet cat6 cable it is 50 mtr long and one side conneted in 8 port switch but my computer is not connected properly its randumly loss the connection plz help me
1 answer Last reply
More about making ethernet wireless
  1. Try a different port or a cable? Need to narrow down where the issue is. You can get a wireless router or access point if you want though, easy to do. Buy a WiFi access point, set it up, get a wireless card for the PC.
LAN Wireless Ethernet Card Networking
