I'm building my first computer and already ordered the stuff but am having second thoughts about my cpu. I got the Amd Phenom ii 1045t for $89 with http://www.gigabyte.com/products/p [...] id=4305#ov mobo, 8 gb ram. I use it for gaming but nothing too extreme.
I was looking at maybe getting one of these
fx 6300 for $129
fx 8320 for $149
would any of those make that much of a difference if i got one of them instead? Or should i just keep the 1045t? And would the fx8320 work on that mobo fine out of the box? and the power supply i got is 400W would i need a bigger one with any of those cpu's
thanks
also have a GeForce 9600 GSO from my old comp. what would be a good graphics card for around $120 or less and again would i need a bigger psu if i got a new card
fx 6300 for $129
fx 8320 for $149
thanks
