[Q]How is this Build? ElmoisEvil need help
Last response: in Systems
Can I cut down any more. Will be using only for gaming and no change for 3-4 years
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($199.99 @ Newegg)
Motherboard: ASRock B75M-GL Micro ATX LGA1155 Motherboard ($67.55 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($63.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
Video Card: Sapphire Radeon HD 7950 3GB Video Card
Case: Cooler Master Elite 335 ATX Mid Tower Case
Power Supply: Antec Basiq 500W ATX12V Power Supply ($65.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
Monitor: Acer G205HVbd 20.0" Monitor ($108.98 @ Newegg)
Total: $901.46
(Generated by PCPartPicker 2013-02-08 14:28 EST-0500)
Total: $901.46
More about : build elmoisevil
Related ressources
- Is ElMoIsEviL a reality denier? - Forum
- PSU Basic Knowledge - Forum
- AMD failure rate - Forum
- 1st time builder here! Its exciting but I need help :( - Forum
- Cell Phones and Smartphones Frequently Asked Questions - Forum
Quote:
Can I cut down any more. Will be using only for gaming and no change for 3-4 yearsPCPartPicker part list / Price breakdown by merchant / Benchmarks
Total: $901.46
Changed Now..
13thmonkey said:
crossed in the ether, calm down. your weakest part is still the HDD, SSD's are the future, but you'll only get 128GB for that price. but you can add a second hdd easily later, a lot easier than migrating to an ssd from a hdd.
what OS? win 7 64 (seems to be cheaper now that win 8 is out).
I'm Happy with the HDD, WIN 7 64 bit sounds like a winner. Also mate, I see people talking about the faulty AMD Drivers. What is it?
The Core i5-3330 would also work well as a gaming CPU:
http://community.futuremark.com/hardware/cpu/Intel+Core...
Quote:
I'm Happy with the HDD, WIN 7 64 bit sounds like a winner. Also mate, I see people talking about the faulty AMD Drivers. What is it?not sure, they update them about every 6-8 weeks, so things will be fixed quickly generally, will generally only effect the newest of new games. personally i go with the green team, but the price of amd is really good for the performance. the card you've got is just below a 670, which will cost more .
Quote:
I'm Happy with the HDD, WIN 7 64 bit sounds like a winner. Also mate, I see people talking about the faulty AMD Drivers. What is it?You see people talking about Noah and his Ark as well like it actually happened. People have an odd confirmation bias when it comes to preferences. Call it "team spirit". They will cling to issues a past product may have had and attach those issues to ALL products a company makes.
ATi/AMD used to have a lot of driver issues. They have fixed that reputation for years now (since around 2006). Unfortunately old reputations die hard. Claims of bad drivers still haunt them today even-though nVIDIA have just as many (if not more) driver issues.
Quote:
You see people talking about Noah and his Ark as well like it actually happened. People have an odd confirmation bias when it comes to preferences. Call it "team spirit". They will cling to issues a past product may have had and attach those issues to ALL products a company makes.ATi/AMD used to have a lot of driver issues. They have fixed that reputation for years now (since around 2006). Unfortunately old reputations die hard. Claims of bad drivers still haunt them today even-though nVIDIA have just as many (if not more) driver issues.
Thanks for clarifying that! So My system good for 3 years?
too true, i've had some beta drivers from nvidia with very odd side effects.
Related ressources:
- ForumNew build - AMD or Intel
- ForumCustom Extreme System - Need Case/Cooling + Other Advice
- ForumCritique my build
- ForumC2D Build
- ForumE6400 vs. X2 3800+ build , SLI mobo?
- ForumSolyndra: Round Three
- ForumPlease help !!! Benchmarks... (WinXP)!
- ForumAnother, "which cpu is best"; but with specific considerations
- ForumFolding@Home: THGC Needs You -Team 40051
- ForumBulldozer to be showcased at CeBit
- ForumIs 2600k good for "future-proofing?"
- ForumUpgrading PC after 4 Years(2009) Need Help! [PC Noob]
- More resources
