I've installed new PSU's GPU's and RAM before but never have I built from the ground up. I know sometimes CPU and Motherboard and other stuff doesnt mix. I looked on all the websites and it all seems to check out but I figured I would throw it out to some experts. Can anyone find a problem with this system? Any and all comments appreciated. Also, I know I dont have a GPU and PSU but I can figure that out later. I know those well. I will be using this system for gaming and watching movies. I have a 23 inch monitor and a 60 inch HDTV.
HEC Blitz Black Steel Edition ATX Mid Tower Computer Chassis Gaming Case w/ Front Blue LED 120mm Fan & Top 120mm Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811121096
CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233141
CORSAIR Hydro series H50 High Performance CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor FD8350FRHKBOX
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1199136
BIOSTAR TA990FXE AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
Last, do I really need the fan seeing as the case has two?
