To display images, you can use this format which will directly display the image rather than having to follow the link.
Its functional, but not overly visually pleasing. If you havent got a side panel windows then that doesnt matter though
- See if you can get that cable (USB3?) running in front of the graphics card taped to the roof of the case then down and through the grommet. Use something like black duct tape and it will be pretty invisible.
- Use that duct tape to cover up the yellow wires on the PCI-Express cables.
- Tuck the AC'97 audio connector behind the PSU if you can, under that bottom PCI slot if you cant.
- Whats that cable running across the RAM?
- Get the CPU fan cable tight with as much as possible hidden under the heatsink.
- unplug all the USB/front IO/Audio cables and run them so they don't twine through the power cables. Looks a bit haphazard.
If you want some more tips, drop into the system gallery at the top of the Systems forum. The resident Cable Management Guru (Motopsychojdn) is known to reside there.
