Hello,
i bought a cheap gaming case for my first build the case is a CIT Saturn the case comes with 2 pre installed fans one in the front and one in the side i recently bought some new fans because the stock ones were way to loud but to replace the front fan i need to remove the front panel i can't see any screws just these plastic things under the is a gap which i assumed thats where you put your hand but i don't want to force it of in case it breaks.
any advice Thanks
any advice Thanks
