1st Time builer, need some advice on the parts I've chosen
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811345015
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130827
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131887
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Fans: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
I am also undecided between buying an SSD or HDD:
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152244
SDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227714
Space is a non issue - I don't plan on storing much on either, so 120 gigs or 320 is the same to me. I just want to know if the efficiency is worth it. A couple points to clarify about my intentions and such:
-No intention to overclock or upgrade
-Main goal is to run Tera at max settings/full speeds
-Do not plan to use this PC for storage
-On a budget, don't want to spend a lot
-First time builder
Just wanna know if these parts are good, and which harddrive to go for. Thanks for any advice.
9 answers Last reply
More about time builer advice parts chosen
  1. This is VERY unbalanced. High end CPU and bottom bracket GPU. You want a much better GPU and a worse CPU. What is your budget? I will put something together for you.
  2. Uh, somewhere around 500-700 dollars.
  3. PCPartPicker part list / Price breakdown by merchant / Benchmarks
    CPU: AMD FX-6300 3.5GHz 6-Core Processor ($129.99 @ Amazon)
    Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($79.98 @ Outlet PC)
    Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($43.98 @ Outlet PC)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($74.98 @ Outlet PC)
    Video Card: Galaxy GeForce GTX 660 2GB Video Card ($194.99 @ Newegg)
    Case: Cooler Master Elite 430 ATX Mid Tower Case ($41.98 @ Amazon)
    Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($39.99 @ Newegg)
    Optical Drive: Samsung SH-224BB DVD/CD Writer ($15.98 @ Outlet PC)
    Total: $621.87
    (Generated by PCPartPicker 2013-02-09 14:42 EST-0500)
  4. Oh, pff. I forgot to mention. I plan on reusing RAM from my old computer (4 gigs).
    Bad idea, or should I just buy the new ones you listed?
    Thanks for the help.
  5. I would just grab the RAM in the build. Its not too expensive and no reason to not get it.
  6. Alright. And about the harddrive, I don't think I'll be needing 1TB since I have an exHD with that much space. Should I just get an SSD in that case since it's faster?
  7. Installing games and stuff to an external HDD is never recommended. buy a 500gb HDD. An SSD won't make gaming performance faster at all.
  8. Okay, thanks again for all the help.
  9. No, problem. Always glad to help!
Homebuilt Hard Drives Processors Systems Product
