I built my PC about a week ago and everything has worked great. Today I was browsing the web and as I went to scroll the web page down it started to lag or freeze for about a half second. A few min later I opened up a video and noticed a small crackle in the audio about every second. It almost sounds like how older records used to have that dull crackle in the backround. Everything I purchased was new in the box and carefully assembled. I have my output through an HDMI so audio and video are coming out 1 plug through my graphics card.
CPU - AMD FX-8350
Mobo - Biostar TA990FXE 990FX
GPU - Power Color 7870 LE Myst Edition
PSU - Corsair TX650 650w Bronze Certified
RAM - 8gb Patriot G2 Series 1333MHz (Only one stick the other is fried I'm getting 2 new 8gb sticks this week)
HDD - Western Digital 1TB Blue 7200RPM
The CPU temp hasn't gone over 50c that I've seen. I think I'm going to return my GPU because it seems to get hotter than normal from the reviews I've read. Playing a game such as Crysis 3 Beta the temps hover around 90c and I've seen as high as 94c and thats with fan at full speed. Not sure if a bad GPU would cause such problems so I figured I would come here and ask you guys. Thanks in advance
CPU - AMD FX-8350
