Are my parts compatible
Mother board
PartsMSI Z77MA-G45 - motherboard - micro ATX - LGA1155 Socket - Z77 - LGA1155 Socket
Ram
Corsair Vengeance 8gb Kit ( 2x 4gb ) DDR3 1600mhz Memory
54 pounds
XFX
P1-550S-XXB9 power supply 47 pounds
GPU
7870 amd graphics card
Intel 3rd Generation Core i5-3570K CPU (4 x 3.40GHz, Ivy Bridge, Socket 1155, 6Mb L3 Cache, Intel Turbo Boost Technology 2.0)
I have my own hard drive and optical drive and case
2 answers Last reply
More about parts compatible
  1. Links help a lot
    But yes that is compatible
  2. Good stuff, but are you sure you want a matx board ? there's nothing wrong with matx, but you can find atx standard ones for about the same price(unless you have a micro atx case).
    I'd get the 7870 tahiti le, if possible, since you're in the uk, you might want to take a look at these : http://www.amazon.co.uk/Club-3D-HD7870-Graphics-Processors/dp/B00AAAFE7E/ref=sr_1_1?ie=UTF8&qid=1360531718&sr=8-1
    http://www.ebuyer.com/432444-powercolor-hd-7870-myst-pcs-edition-2gb-gddr5-dvi-hdmi-dual-mini-ax78702gbd5-2dhppv3e
New Build Systems
