Archived from groups: rec.photo.digital.zlr (More info?)
Hello !
When I shake my new Minolta Z10 from back to front and front to back, I ear
a little noise inside, just like a piece of plastic travelling inside (it
seems to be near the viewfinder, but it's dificult to locate...)
I borrough about that...
Is it normal ?
If somebody has the same camera, can he tell me ?
Without this noise, I think the Z10 is a very good digital camera for a low
price !
Alf92 wrote:
> Hello !
> I ear a little noise inside, just like a piece of plastic travelling
> inside (it seems to be near the viewfinder, but it's dificult to
> locate...) I borrough about that...
> Is it normal ?
I don't know, but it doesn't sound normal to me. I suggest you take it
back to the shop and compare with an identical model.
"David J Taylor" <david-taylor@invalid.com> wrote in message
news:33qcs0F43eq5dU1@individual.net...
> Alf92 wrote:
>> Hello !
>> Is it normal ?
> Cheers,
> David
Have you checked the manual, I seem to recall it saying something about this
not being a sign of a fault....
>> Alf92 wrote:
>>> Hello !
>>> back, I ear a little noise inside, just like a piece of plastic
>>> travelling
>>> Is it normal ?
>> it back to the shop and compare with an identical model.
>> Cheers,
>> David
> about this not being a sign of a fault....
> Robert
I hope Robert is right: I know of one camera with a similar note in the
book. It is related to the auto-rotation of images in the LCD viewer, if
I'm not mistaken.
Frank ess a dit ça :
>>> Alf92 wrote:
>>>> Hello !
>>>> travelling
>>>> Is it normal ?
>>> Cheers,
>>> David
>> Robert
> the book. It is related to the auto-rotation of images in the LCD
> viewer, if I'm not mistaken.
the Z10 doesn't have any orientation sensor...
and the user guide doesn't talk about any noise inside the camera.
Cordialement,
Alf92
Here you are, under "Trouble-shooting"....
14: The camera will make sounds caused by internal mechanical movement when
it is shaken.
Answer: The sound arises when the lens moves. This is not a malfunction.
I knew I had read it somewhere.
Robert.
"Alf92" <alf92[NO-SPAM]@freesurf.fr> wrote in message
news:41d85e6e$0$20281$636a15ce@news.free.fr...
>>>> Alf92 wrote:
>>>>> Hello !
>>>>> travelling
>>>>> Is it normal ?
>>>> Cheers,
>>>> David
>>> Robert
> Cordialement,
> Alf92
Bill Again a dit ça :
> movement when it is shaken.
> malfunction.
> Robert.
I went to the shop and I compare with other Z10 : same strange noise !
It is normal.
David J Taylor a dit ça :
>> ! It is normal.
>> Thanks.
> Oh, well. That's good to hear! Thanks for reporting back.
As we say in France "de rien !"
I think it's normal when you have the answer to share it.
In article <33qcs0F43eq5dU1@individual.net>, david-taylor@invalid.com says...
> Alf92 wrote:
> > Hello !
> > Is it normal ?
> Cheers,
> David
Orientation sensor???
most of those rattle some
Larry Lynch
Mystic, Ct.
