Hi everyone,
I am building a new rig to replace an ancient PC at home and would greatly appreciate any thoughts you may have on the configuration I've included below.
Approximate Purchase Date: this week
Budget Range: <$3,000
System Usage from Most to Least Important: Photo editing (Lightroom & Capture NX), MS Office, music, internet browsing. No gaming.
Are you buying a monitor: No. Resolution of current monitor is 1920x1200. Single monitor set up.
Do you need to buy OS: Yes - Win 8 Pro 64-bit
Preferred Websites for Parts: newegg.com & amazon
Overclocking: Maybe or Not at all
SLI or Crossfire: No
Additional Comments: This is the current plan - hope it's "futureproof" enough to last at least 5 years, stable, and fairly quiet.
Processor: Intel Core i7-3930K
Motherboard: ASUS Sabertooth X79
RAM: G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1866 (PC3 14900) F3-14900CL9Q-16GBXL [On the mobo QVL]
Graphics Card: EVGA Superclocked, Signature 2 02G-P4-2687-KR GeForce GTX 680 2GB 256-bit GDDR5
SSD: SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB [For Windows & programs only]
HDD: SEAGATE ST2000NM0033 Constellation ES.3 2TB 7200 RPM 128MB cache SATA 6.0Gb/s [For all data files]
This is a new Seagate Entreprise drive so doesn't have many reviews out. Initially I thought of buying a RAID PCI card so I can have two 2TB drives in RAID 1 mode for full hardware redundancy, but then decided to consider this one to avoid the extra cost and potential complications of a RAID configuration.
Power Supply: CORSAIR Professional Series Gold AX850
Initially I was tempted to get the AX860 to take advantage of the Platinum efficiency, but it seems many users are experiencing noise problems. I also considered the AX860i but don't see much value in monitoring the PSU via software, plus the Cross Link software appears not be fully ready yet for Windows 8.
Cooling: CORSAIR Hydro H80i. I'm also considering the Noctua NH-D14 SE2011 to avoid the potential (small) risk of a leakage and the potential kinks of the new Corsair (e.g. software compatibility with Win 8), however the Noctua's size is monstrous and I won't have access to the DIMMs. According to the Noctua website, this cooler is compatible with both the mobo and RAM I have chosen. Also I have seen pictures of it installed in the Define R4 case therefore it fits.
DVD Burner: LG 14x SATA Blu-ray Internal Rewriter
Case: Fractal Design Define R4
Thanks in advance!
Thanks in advance!
