Problem with 6230
  • Nokia
  • Phones
Last response: in Brands
Anonymous
May 9, 2005 10:45:18 PM
Archived from groups: alt.cellular.nokia (More info?)
Hi all,
Was wondering if someone knows what might be wrong with my phone, a
Nokia 6230.
When you switch it on, it works just fine for up to about 30 minutes.
After this, if someone rings me, the phone vibrates and the screen
shows the incoming call. However the ringtone stays silent and when I
accept the call it just cuts the other person off.
The fault is apparent, whether bluetooth is on or off, and no matter
what MMC card I have in, or none at all.
When this occurs, you have to reboot the phone to get it working
again. It has been doing this for a few weeks now. Never dropped it.
Software version 03.15 if that helps. On Orange (UK).
Any help would be appreciated.
Paul
Paul Gledhill
Et in Arcadia Ego...
More about : problem 6230
Anonymous
May 10, 2005 1:49:47 AM
"Paul Gledhill" <paul@anomalySPAMIT.co.uk> wrote in message
news:hn7v719ch7fffur5c2jimanb7h8bdk3gmn@4ax.com...
> Hi all,
> Nokia 6230.
That's an early version. Get it to a service centre under guarantee (take
the docs Orange sent you) and they'll update it for nothing.
Mine is a later version and it's still flaky and inclined to disconnect with
a "SIM missing" message.
Shame, if it worked it'd be a great phone.
Brian
"Anyway, if you have been, thanks for listening."
Anonymous
May 10, 2005 3:06:07 AM
Well do as you advised original poster.6230 is now on firmware version
5.35.Im using 5.24 and it works flawlessly,great phone
regards
"Brian Watson" <news@spheroid.demon.co.uk> wrote in message
news:D 5oidc$bg6$1@domitilla.aioe.org...
>> Hi all,
>> Nokia 6230.
> with
> Brian
Anonymous
May 10, 2005 10:22:32 AM
"DracUK" <dracuk100@dracuk100NOSPAM.karoo.co.uk> wrote in message
news:cHudnZM6i_1OQ-LfSa8jmA@karoo.co.uk...
Will do. My first one had an internal clock fault that meant it would not
take an upgrade, my replacement one now needs the upgrade to work properly.
Just a matter of finding the time to get it to a service centre...
Brian
May 13, 2005 9:55:37 AM
Check that the phone is not set to autoanswer.
It might be that the hone is answering, and when you press to answer
manually that you are actually ending the call.
Sandy
> Hi all,
> Nokia 6230.
> Paul
> Paul Gledhill
Anonymous
August 1, 2005 10:47:02 PM
How do you find out what version is on the phone?
Thanks,
Carol Van
> regards
Anonymous
August 2, 2005 1:18:07 AM
"Carol Van" <> wrote in message ...
Type *#0000# into the phone.
Mike.
Anonymous
August 3, 2005 9:45:44 AM
Thanks
"Mike H" <dot@dot.dot.dot.moc> wrote in message
news:42ee837e$0$6467$cc9e4d1f@news-text.dial.pipex.com...
> Mike.
