Do you know if these parts are compatible
Last response: in Systems
February 11, 2013 11:21:09 AM
http://www.ebuyer.com/251596-intel-core-i5-2500k-3-3ghz...
Gigabyte GA-B75M-D3V Socket 1155 PCI-E 3.0 Quad CrossfireX/SLI USB 3.0 VGA DVI 8 Ch Audio mATX Motherboard £45
http://www.ebuyer.com/search?q=GSKILL+8GB
xfx 7870 amd graphics card £150
http://www.ebuyer.com/search?q=500GB+Seagate+Barracuda
XFX
P1-550S-XXB9 power supply £47
http://www.ebuyer.com/343468-coolermaster-elite-371-com...
http://www.ebuyer.com/397468-samsung-sh224bb-bebe-sh224...
Fan: Thermaltake 120mm AF0022 Smart Case Fan II with VR Controller £10
More about : parts compatible
February 11, 2013 11:38:29 AM
They are compatible but if you are getting a 2500K, you'll need either a P67/Z68/Z75/Z77 motherboard for overclocking. If you are not overclocking, it's better to get the i5-3470 unless the 2500K is significantly cheaper.
Other than that, the rest of the specs are fine. No compatibility issues. Make sure the video cards fits in the case. I'm sure it will but double check that. See the manufacturers website for dimension details.
February 11, 2013 3:57:37 PM
B75 motherboards prohibit access to the multiplier so if you're buying the 2500K you will want one of the aforementioned motherboards. Better would be to get the 3570K which isn't much more and is based on newer architecture.
