Closed
Multiple Monitor Help
So today I picked up an XFX 7770 in hope of running all 4 of my monitors at once.
The card has:
-2x DVI ports
-1x HDMI
-1x DisplayPort
How should I go about connecting the monitors to the graphics card to run all 4 at once?
Thanks
4 answers Last reply
More about multiple monitor help
  1. You can't. End of story. You should have done research first. one of the DVI Ports shares the signal with the HDMI Ports. Monitors 3 and 4 must be connected via display port. You only have one display port, and there are no display port splitters on the market, so you can only connect 3 monitors. The third must use an active display port to DVI adapter
  2. The box says "Supports up to for monitors"
    Could I do this? DisplayPort to DVI and then use a DVI splitter?
  3. Bump
Graphics Cards DVI Monitors Graphics
