Closed Solved
Cabinet problem
hi guys i am going to upgrade gpu to hd7770 and i am confused whether the gpu is large in size and
whether it will fit into my cabinet or not
cabinet : http://www.zebronics.com/products/cabinet-reduced-height/king
gpu : http://www.sethiainfotech.com/msi-radeon-hd-7770-ghz-edition-1gb-gddr5-pci-e-graphic-card-r7770-2pmd1gd5-oc.html
and i also want to know whether this gpu fits my motherboard also
mobo: intel dh61ww
how much power supply does this gpu requires and does it requires any pci-e connector
thank you in advance...
4 answers Last reply Best Answer
More about cabinet problem
  1. Best answer
    aroud here it's called a "case" not a "cabinet". yes it will fit, unless you do something strange inside your case or get an unnecessarily long card. Look at the inside and measure. It takes one connector and 80-90w.
    edit: the linked card is on the long side, look for an 8.5 if you're worried.
    is buying the above gpu is on safe side or not for this case. because this is the lowest price for that gpu
  3. It should, it's a small case and small card, but I can't give you a definate answer without knowing what the inside of the case looks like.
  4. Best answer selected by harishphk.
Graphics Cards GPUs Power Supplies Motherboards PCI Express Graphics Product
