Need help with new build fan connection
I got my parts in last week (unfortunately the PSU was DOA so I had to RMA it) When I was putting it together, I noticed the ASRock H77M mobo i bought did not have enough fan connectors for my case fans (I need 3).
I would like to find a cable or splitter which will allow me to connect these fans while maintaining decent cable management. I believe I could use a Molex to 3-pin adapter but I couldn't find one with 3 3-pin connectors.
If anyone has any cable recommendations for this, I'd greatly appreciate it.
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
3 answers Last reply
More about need build connection
  1. Your board has 5 fan connections
    4 pin CPU
    3 pin CPU
    3 pin CHA Fan X2
    3 Pin PSU
    Can you provide addational information reguarding all fans case and CPU
    4 pin CPU
    3 pin CPU
    3 pin CHA Fan X2
    3 Pin PSU
    Case is the NZXT Tempest 410 elite.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080&Tpk=nzxt%20tempest%20410
    Comes with 3 fans. The two CHA Fans on the top right are hard to reach with the fan cables provided, unless I go through the top of the case next to the CPU Fan, which I don't really want to do.
New Build Connection Cable Systems Product
