Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems with Call of Duty UO MP.
Forum Windows XP : Windows XP General Discussion - Problems with Call of Duty UO MP.
Archived from groups: microsoft.public.windowsxp.games (More info?)
Hello All
when loading into CoD:UO MP and start loading into a map, right after
loading and l get to the weapon selection screen, my computer frezzes up and
makes a "Teeee" sound and then reboots. This happens each time l join MP and
l get the same error message, which is....
Event Type: Error
Event Source: nview_info
Event Category: None
Event ID: 1
Date: 4/6/2005
Time: 9:03:30 PM
User: N/A
Computer: PAUL
Description:
The description for Event ID ( 1 ) in Source ( nview_info ) cannot be found.
The local computer may not have the necessary registry information or message
DLL files to display messages from a remote computer. You may be able to use
the /AUXSOURCE= flag to retrieve this description; see Help and Support for
details. The following information is part of the event: NVIEW : washer:
WAIT_TIMEOUT, while waiting for a read to clear - resetting read event
any help would help out alot
thanks in advance
Sponsored Links
Hi Jason,
Hardware issues can cause freezing, black screens and other
errors. Also, your drivers should always be kept up to date.
Try the following steps one at a time to try and resolve the issue.
I hope this helps. Please post back if you have any questions! :-)
1. Update DirectX and your Chipset, Sound, &Video Drivers:
For all Video / DirectX / Game and Hardware Issues, I have a
Checklist of Solutions at: http://NibblesNbitsVideo.tk
2. Dust your fans, vents and components using a 1/4" paintbrush
and a hose vacuum. Use compressed air for hard to reach places.
Set a housefan to blow cold air into your case to expose an over-
heating issue.. If it works add more fans or replace defective ones.
Use this Motherboard Monitor Utility: http://mbm.livewiredev.com
3. A faulty power supply can cause STOP errors, random reboots,
and black screen lockups. One way to test for that is to check the
wattage sticker on your power supply and then calculate your need
http://www.jscustompcs.com/power_supply/ (Min. 350 for gaming)
4. Test your RAM using: http://oca.microsoft.com/en/windiag.asp
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/defau [...] ;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"JasonP" <JasonP@discussions.microsoft.com> wrote in message news:DA29D190-0449-44EA-8541-AE210DB50C9D@microsoft.com...
> Hello All
> Event Type: Error
> Event ID: 1
> Date: 4/6/2005
> Time: 9:03:30 PM
> User: N/A
> Computer: PAUL
> Description:
> thanks in advance
Reply to Anonymous
Hello Jimmy
Thanks for the help, the problem ended up being that COD didn't read the
newer Graphic drivers so l reinstalled the game. Also l upgraded the drivers
for my chipset which seem to help also. Once again thanks for the help, for a
fast reply and a quick fixs
regards
Jason
"Jimmy S." wrote:
> Hi Jason,
> > Hello All
> > Event Type: Error
> > Event ID: 1
> > Date: 4/6/2005
> > Time: 9:03:30 PM
> > User: N/A
> > Computer: PAUL
> > Description:
> > thanks in advance
Reply to JasonP
Glad that worked out for you Jason! :-)
Cheers,
Jimmy.
"JasonP" <JasonP@discussions.microsoft.com> wrote in message news:7E2718A1-58D5-4817-B08C-9DA21D302C78@microsoft.com...
> Hello Jimmy
> regards
> Jason
> "Jimmy S." wrote:
>> Hi Jason,
>> > Hello All
>> > Event Type: Error
>> > Event ID: 1
>> > Date: 4/6/2005
>> > Time: 9:03:30 PM
>> > User: N/A
>> > Computer: PAUL
>> > Description:
>> > thanks in advance
Reply to Anonymous
There are 889 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
