Need advice between Nvidia Geforce GT 630 and AMD Radeon HD 6670
  • Graphics Cards
  • Graphics
  • Product
December 27, 2012 10:21:17 AM
I'm planning to buy one of those video card and I don't which one. I searched the Internet and they said that the Radeon HD 6670 is better. Is this true? If it is, is it compatible with my computer? My spec. is listed below:
- Processor: AMD Athlon II X2 250 Processor 3.00 GHz
- Installed Memory (RAM): 4.00 GB
- DirectX Version: DirectX 11
If your still lacking information, please tell me. I'm not really knowledgable about computers.
More about : advice nvidia geforce 630 amd radeon 6670
a c 182 U Graphics card
December 27, 2012 10:31:37 AM
yes hd 6670 is better than gt630.
please tell your budget,motherboard info,power supply info of your pc
m
l
December 27, 2012 10:37:16 AM
Ok, hold on...
m
l
December 27, 2012 10:41:12 AM
- budget: 60 - 100$
- motherboard - EMMAX Technology
- motherboard model - EMX-AMD880HD3-PRO
- power supply - (I can't seem to find this, help?)
m
l
December 27, 2012 10:54:17 AM
Is there any other way to check the PSU besides opening the CPU?
m
l
December 27, 2012 10:59:32 AM
Wait, all I know about my power supply is its 400 watts
m
l
December 27, 2012 11:12:27 AM
ok i will recommend you good card for you.
whats your max resolution of screen
m
l
December 27, 2012 12:53:10 PM
Sorry for the late reply. My max resolution is 1024 x 768.
m
l
December 27, 2012 1:12:47 PM
Thank you so much with your help. I really appreciate it. :)
m
l
December 27, 2012 1:16:43 PM
Wait, one last question. Sapphire Radeon HD 6670 and Gigabyte AMD Radeon HD 6670 are the same right? Only the manufacturer is different, correct me if I'm wrong. Thanks again for your help.
m
l
December 27, 2012 1:22:16 PM
yes they are same gpu.just different manufacturer.
m
l
