M mervindj Honorable Mar 12, 2012 1 0 10,510 Mar 12, 2012 #1 Hi Please help me, i'm going bananas here. Laptop starts up boots up and switches off again. startup repair shows problem signature as above. Please help
das_stig Glorious Jul 24, 2009 8,291 33 46,040 Mar 12, 2012 #2 OS has become corrupt, now you can try recovering using the guide or just reinstall using the reovery partion or from DVD. To repair .. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true Then at the dos prompt type "chkdsk c: /r" without quotes. Can take a few hours to scan and correct any errors, at the end keep a look out for anything that reports bad clusters, a sign that the disk is dying. Upvote 0 Downvote
