Tom's Hardware > Forum > Mobility Brands > Nokia > Nokia 9210 key pad problems
Forum Mobility Brands : Nokia - Nokia 9210 key pad problems
Archived from groups: alt.cellular.nokia (More info?)
Hi all,
I encounter (a lot of) problems with my numeric key pad on my Nokia
9210 communicator; the 2-key has stopped functioning at all and the
availability of the ofter keys is sometimes ""shaky".
I already dismantled the phone a bit and tried to clean it, but to no
avail.
A - Does any one know how to dismantle a Nokia 9210 (where all the
crews are etc.)
B - what could be the problem; i think it might me loose contact, but
am not fully sure
C- Has any one ever encountered the same problem and what is/was the
solution.
I'm eager to hear solutions to my problems. It's hard (if not
impossible) to dial people that have a "2" in their phonenumber.
wijnand
Sponsored Links
Dismantle info here http://www.uselessinfo.org.uk/
Click on Nokia DCT-L link. You need a special screwdriver (T6)
available at most electronic shops. Do not use "allen keys". They will
"screw" the "screws".
Have you simply tried a new keypad???? The little plastic "pins" under your
keypad can bend or wear down after excessive use.
Good Luck
<wijnand.wellink@gmail.com> wrote in message
news:1115889984.775583.79390@g43g2000cwa.googlegroups.com...
> Hi all,
> avail.
> crews are etc.)
> am not fully sure
> solution.
> wijnand
Reply to deceptor
There are 1167 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
