Picture doesn't fit screen when using TV as monitor.
  • Graphics Cards
  • TV
  • Resolution
  • Monitors
  • Graphics
  • Displays
December 27, 2012 4:10:25 PM
Hello,
I received a 32" tv for Christmas to start using as a computer monitor for gaming. The TV does support 1080p resolution. My video card has HDMI output. My problem is I am unable to display the monitor in 1920*1080 resolution. It seems to stretch over the screen in every direction. Just barely, but enough it is noticeable and would make gaming challenging due to UI layouts. I am playing at a smaller resolution and it's working, just not ideal. Any suggestions for being able to display 1920*1080? There was a setting on the TV to change from Wide display to Dot by Dot display, which made a huge difference in the overall picture quality, but the picture still does not fit the screen. Any help or advice is much appreciated.
Thanks everyone.
More about : picture fit screen monitor
a b U Graphics card
December 27, 2012 4:34:53 PM
make sure the GPU is outputting the correct resolution, then maybe you have to adjust the position settings in the TV.
m
l
December 27, 2012 5:27:32 PM
There should be scaling options for HDTV's in catalyst control center and nvidia control panel. Be sure the resolution is set to 1920*1080 in the graphics control panel and then change the scaling options untill the picture fits the screen correctly.
m
l
