Need some some help with a problem I have never come across before.
I have a Toshiba 1612 DVD which until today was OK. Now it will not read any
.exe file or carry out autorun function.(Will read all other files on disk and works ok.,
for example if I ask it to open a text file, .doc, .pub etc associated program opens
normally).
If disk with autorun on is loaded, message "Windows XP has encountered a problem and will
now
close" appears.
If I use Explorer and click on the .exe file, message ERROR "Only part of a Read Process
Memory or Write pPocess Memory request was completed".
If I ask it to copy the .exe file to my Hard Drive works perfectly and then file will load
normally from the Hard drive therefore DVD must be reading file ok.
The other funny bit is if I put the same disk into either of my CD Writers they both work
perfectly normal both on autoload and if I click on .exe file.
This has got me stumped any help would be appreciated.
Rules are for the guidance of the wise and the obedience of fools.
normally).
now
close" appears.
