Possible graphics card problem?
parallelTom555
I just ordered myself a new custom built pc. I receved it around 4 days ago now and after unpacking it and plugging in all the neccesary cables I discovered that it was not displaying anything through the HDMI or DVI port (monitor is vga, using vga to dvi converter). I have tried removing the card and running from the on-board graphics which works fine. The fans of the GPU run, the motherboard beeps once which indicates everything is running correctly, however, no display or power to usb ports when using the gpu.
Could this be a bad gpu? Or something else?
Specs are as follows:
InWIN MANA-136 BLACK GAMING CASE
Intel® Core™i5 Quad Core Processor i5-3570K (3.4GHz) 6MB Cache
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
8GB SAMSUNG DUAL-DDR3 1333MHz (2 X 4GB)
3GB AMD RADEON™ HD7950
1TB 3.5" SATA-III 6GB/s HDD
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler
