Help on first build
Last response: in Systems
Hello, I'm just about ready to order the parts for my first build however there are still a few things I need help on before I get there, first off is my fan set-up I am going for the Cooler Master HAF 912 Plus and I have no idea how I should set up the fans.
Also I wanted to know if my build can run these games on ultra: Battlefield 3, Witcher 2, Planetside 2, Crysis 3 and Metro 2033
My Build:
Case: Cooler Master HAF 912 Plus Black Midi Tower Gaming Case
Motherboard: Asus P8Z77-V LX Motherboard (Socket 1155, 32GB DDR3 Support, ATX, Intel Z77 Express, USB 3.0, CrossFireX Support, Dual Intelligent Processors 3)
CPU: Intel 3rd Generation Core i5-3570K CPU (4 x 3.40GHz, Ivy Bridge, Socket 1155, 6Mb L3 Cache, Intel Turbo Boost Technology 2.0)
CPU Cooler: Cooler Master Hyper 212 EVO CPU Cooler for All Intel/AMD CPU's
GPU: ASUS GeForce GTX 670 DirectCU II OC 2GB GDDR5
HDD: Seagate Barracuda© SATA 6Gb/s 1TB Hard Drive ST31000524AS
RAM: Kingston 8GB 1600MHz DDR3 XMP HyperX Predator Memory
PSU: XFX P1-650S-UKB9 Pro Series Core Edition 650W Power Supply (PSU)
DVD Writer: Liteon Ihas120 20x Dvd±rw (dual ±r)/ram Sata Drive
Monitor: 21.5" AOC E2250SWDAK LED Monitor, Full HD, DVI/VGA, 1920x1080, 5ms, 250cd/m², 20M:1, Speakers
OS: MICROSOFT Windows Home Premium 7 SP1 64-bit EN 1pk - OEM [GFC-02050]
Mouse and Keyboard: GIGABYTE KM6150 Wired Black USB Keyboard & Mouse Bundle
SSD: Sandisk 64GB Pulse SSD
Thanks for the help :D
More about : build
Thanks for the replies :D  .I don't really care about not having a front 3.0 port, and unfortunately I live in the UK so no newegg. And I am only using an SSD for the OS but if you think that an SSD was not of much use I would be prepared to lose it.
So does anyone know if this build will run the games listed above
