PowerColor Radeon HD 7850 1GB vs SAPPHIRE Radeon HD 7850
i am building my own pc and i want to know which is better:
SAPPHIRE 100355-1GOCL Radeon HD 7850 1GB:
(http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...)
or
PowerColor Radeon HD 7850 1GB:
I will be playing borderlands 2 and shogun 2 thnx
p.s price counts so if your giving me another gpu that is more expensive then it has to be below $200
bigshootr8 said:
I would take a serious look at this gtx660 card it after rebates goes below 200 dollars. With you playing borderlands 2 I can tell you the difference between using physx in that game and not is huge in terms of visual showcasing.
If i decide to get a gtx card i will be getting the 650 because i live in canada so its costs more. so is the 650 ti better than the hd 7850? and does it use physx?
Oh well look on newegg canada. Only nvidia cards use physx that is correct. Canada prices are a little smaller in terms of pricing here is a 660 card at ncix
http://www.ncix.com/products/?sku=76163&vpn=GV-N660OC-2...
here is a link of where you can get the canadian pricing of 660 cards
http://pcpartpicker.com/ca/parts/video-card/#c=114
here is a super cheap 650Ti from ASUS
and the link I used to find the cards for the 650 Ti's
http://pcpartpicker.com/ca/parts/video-card/#c=118
The 650Ti holds up well against the 7850 in most games. I would use this benchmark as a basis of comparing but with a open eye that with drivers things may have changed. In games that AMD has historically done well on the 7850 does better however in most games the 650Ti holds its own. And you get physx in the process and borderlands 2 uses that as well as other games.
http://physxinfo.com/index.php?p=gam&f=pc
http://www.anandtech.com/bench/Product/680?vs=549
