Help on Graphics Card Upgrade.
I have a HP Compaq dc7700 Small Form Factor.
HP Website
I'm not quite sure how to base a upgrade on my current information. I don't want my power supply to over heat. The power supply says 240w Max. Im looking to upgrade to best the graphics card possible. Any help is very appreciated.
I read the manual a little bit and it says
"You can install a PCI Express x1, x4, x8, or x16 expansion card in the PCI Express x16
expansion slot."
System Information
Time of this report: 12/27/2012, 20:49:17
Machine name: *****
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.120821-1629)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dc7700 Small Form Factor
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) D CPU 3.40GHz (2 CPUs)
Memory: 3048MB RAM
Page File: 931MB used, 4001MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: Intel(R) Q965/Q963 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) GMA 3000
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2992&SUBSYS_2801103C&REV_02
Display Memory: 256MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5016 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 12/12/2008 12:34:42, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 12/12/2008 10:33:58, 6048768 bytes
Device Identifier: {D7B78E66-6AD2-11CF-1460-0B08A3C2CB35}
Vendor ID: 0x8086
Device ID: 0x2992
SubSys ID: 0x2801103C
Revision ID: 0x0002
Revision ID: 0x0002
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
5 answers Last reply
More about help graphics card upgrade
  1. Please let me know if there is additional information need. I appreciate your time.
  2. Has anyone dealt with this type of thing before?
  3. My understanding is I have a PCI Express 16x slot in my computer. Depending on the the graphics card i get i need to make sure i have enough wattage to run it.
  4. hmm why do you want a new graphic card (( is it for gaming )) ?
    i guess the best that you can get is like buried from years and years ago :D
    the best you can get is 6800 gtx 256 bit i guess you are going to do fine with it because i used to have 2 6800 sli and it was the best since the 8800 gtx and the 9800 gtx
  5. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127611
    MSI 6570. Very stable, used it on my 220w Power Supply computer and had 0 issues.
Graphics Cards Graphics Product
