I'm on a very tight budget.
Is a Dual Standard 120MM Fans (Push-Pull) much better than just a Single Standard 120MM Fan, its only a 10 dollar difference but I am on a very tight budget. Also any other advice, particularly attributed to gaming to maybe better my pc, but keep me within the same budget range would be appreciated. I am purchasing a computer mainly for gaming and with these specs:
Case: Thermaltake Commander Mid-Tower Gaming Case (Black Color)
Laser Engraving: Custom Message - Max 35 characters (including spaces) (Courier New)
Extra Case Fan Upgrade: Default case fans
CPU: Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 (All Venom OC Certified)
Cooling Fan: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: Standard Coolant
Motherboard: * [CrossFireX] GIGABYTE GA-Z77-HD3 Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Ultra Durable 4 Classic, 7.1 HD Audio, GbLAN, 2x Gen3 PCIe x16, 2x PCIe x1 & 2 PCI (Extreme OC Certified)
Memory: 16GB (8GBx2) DDR3/1600MHz Dual Channel Memory [Free upgrade from 8GB Major Brand + Double Memory] (Kingston HyperX [Free upgrade from 8GB Major Brand + Double Memory])
Video Card: AMD Radeon HD 7770 1GB 16X PCIe 3.0 Video Card (Major Brand Powered by AMD)
Power Supply Upgrade: 600 Watts - Corsair CMPSU-600CXV2 Builder Series CX600 V2 80 Plus Certified Power Supply
Hard Drive: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
