delta force problem plz help
Archived from groups: microsoft.public.windowsxp.games (More info?)
i had a problem saying that i had a 16 bit subsystem so i fixed that
cos it wouldent install and now it get to 99% on install wizard and
it come up with an error saying file error cannot find WINOLDAP.MOD
some one plz help i do not know what it means :(
1 answer Last reply
More about delta force problem help
  1. Archived from groups: microsoft.public.windowsxp.games (More info?)
    Hi Bahumut666,
    Try installing and playing that using 95/98 Compatibility mode.
    To install a program using Windows XP's Compatibility Mode, hold
    down SHIFT as you insert the game CD, use My Computer to browse
    to the setup program, and then skip down to step 1 in the list below:
    To run an installed program using Windows XP's Compatibility Mode,
    first right click the program and "Send To..." / Desktop (create shortcut).
    1.. Right click on the shortcut to the program.
    2.. Click on Properties.
    3.. Click on the Compatibility tab.
    4.. Click on Run this program in compatibility mode and select one of these:
    a.. Windows 95
    b.. Windows 98
    c.. Windows NT 4
    d.. Windows 2000
    5.. Under Display settings, check mark the mode that you think that is best:
    a.. Run in 256 colors.
    b.. Run in 640 X 480 screen resolution.
    c.. Disable visual themes.
    Click on Apply.Click on Ok.Double click on the program.
    Of course, let's not forget to check for any patches or updates for that game.
    A good place to find them is: www.avault.com/pcrl/patches_list.asp?letter=a
    If you'd like to learn more information about compatibility mode, you can click the
    link in the Compatibility tab that reads "Learn more about program compatibility",
    or watch this Application Compatibility Power Point Presentation:
    http://support.microsoft.com/servicedesks/webcasts/wc112202/WC112202.ppt
    Cheers, Windows XP MVP Shell / User
    Jimmy S. http://mvp.support.microsoft.com
    Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
    Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
    MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
    My advice is donated "AS IS" without warranty; nor do I confer any rights.
    _________________________________________________________
    "bahamut666" <brycenunns557@hotmail-dot-com.no-spam.invalid> wrote in message news:SbmdnYNqOeIczfnfRVn_vQ@giganews.com...
Games Microsoft Windows XP
