Approximate Purchase Date : Over the next 2-3 months for part one.
Budget Range: less than $3k
System Usage from Most to Least Important: (gaming, 3D design programs, surfing the internet, watching movies)
Are you buying a monitor: Yes 3 Dell Ultrasharp U2312HM
Parts to Upgrade: (All)
Do you need to buy OS: Yes MS Win 7 64bit
Preferred Website(s) for Parts: ( newegg.com, ncix.com, amazon, tigerdirect)
Parts Preferences: by brand or type : intel bodx79sr, i7 3820, MSI N660Ti , XFX pro850w XXX edition semi modular 80 plus silver certified, OCV 120 GB SSD, WD 15EZRX 1.5 TB hard drive, corsair 16GB (2x8gb) cooler master HAF 932,
Overclocking: Maybe
SLI or Crossfire: Yes
Your Monitor Resolution: 1920x1080
Additional Comments: I would like to put together this computer over a few months. This is going to start out with the basic configuration and grow from there.
Part one is going to be case, CPU, motherboard, graphics card, power supply, 16GB ram. Will use current 22" monitor (or 47" samsung HDTV) keyboard & mouse from an old machine.
Part two build custom desk or convince wife to let me build a computer room ie mancave! Currently have an executive office set up but it will not accommodate a triple or quadruple monitor setup. Better half doesn't understand technology and thinks my older laptop will be "just fine". It will work if I turn down the settings on some games.
Part three install second graphics card, purchase 3 dell monitors, buy a used Logitech Z5500 5.1 system, G27 wheel, & Logitech joystick.
And Most Importantly, Why Are You Upgrading: I ditched the desktop a few years ago after my computer had a few problems (Motherboard & powersupply went out HD crashed twice. I got frustrated and gave the thing away to my uncle who frankenstined the thing to work again. After that I didn't need a powerful machine and picked up a laptop from Costco. Now I'm looking for an affordable machine to run my programs, proE, solid works, auto desk Revit, and all the current games.
Part list from new egg:
Cooler Master HAF 932 Advanced model # RC-932KKN5-GP
Intel model # BOXDX79SR
Intel CPU model # BX80619i73820
XFX PRO850W model # P1-850-LGN9
MSI N660Ti PE 2GD5 model # N660Ti PE 2GD5/OC
OCZ Vertex 3 Series (SSD) model # VTX3MI 25-SAT3-120G
Western Digital HD Caviar Green 1.5TB model # WD15EZRX
CORSAIR DOMINATOR 16GB model# CMP16GX3M2A1600C10
Dell UltraSharp 23" model # 469-1253
Overclocking: Maybe
