Hi everyone,
I am looking to build my first PC and I was looking for some input regarding my components. I just want to make sure that I am looking at the right stuff and would be interested to know what you all think.
CPU - AMD FX-8350 4.0GHz ($199, http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284)
Motherboard - MSI 990FXA-GD65V2 Desktop Motherboard - AMD 990FX Chipset - Socket AM3+ ($123, http://www.newegg.com/Product/Product.aspx?Item=N82E16813130677)
Video - Gigabyte GeForce GTX 650 Ti 2GB ($175, http://www.newegg.com/Product/Product.aspx?Item=N82E16814125446) OR a EVGA GeForce GTX 660 2GB ($220, http://www.newegg.com/Product/Product.aspx?Item=N82E16814130825)
Memory - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL ($50, http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314)
Power Supply - Corsair CX600 600W 80 Plus Bronze Certified ($80, http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028)
For a HDD and Optical Drive, I am just going to grab a 500GB or 1TB HDD and a standard DVD burner drive for now.
I would like to know if all these components are compatible. As far as I can tell they should be but I am new at this and would like a second opinion. I would also like to know if there are any areas of this list that I could cut back on to save some money and still maintain the CPU and the video card. With the motherboard, I am not sure if I am making the right choice, so input regarding that would be very much appreciated. Same for the power supply, I would like to stick with a modular, 80 Plus certified model but I do not fully know the power requirements of all these components.
I hope to get some good advice from this. Thank you all in advance.
Colton
Colton
