Yo,
I'm planning on buying/building a PC between £500 - £600 and have come across this barebone bundle:
http://www.novatech.co.uk/products/barebones/bb-63008a.html
Of course, it doesn't contain a GPU, OD, HDD or operating system and I therefore wanted to check if these are compatible with it.
GPU: http://www.novatech.co.uk/products/components/amdradeongraphicscards/amdhd7850series/fx-785a-cnjc.html
OD: http://www.aria.co.uk/Products/Storage/Hard+Drives+-+Internal/3.5+Inch+SATA+Drives/160GB+-+600GB/500GB+Western+Digital+Caviar+Blue+WD5000AAKX+3.5%22+SATA+III+Hard+Drive+-+HDD+?productId=43780
HDD: http://www.aria.co.uk/Products/Storage/Hard+Drives+-+Internal/3.5+Inch+SATA+Drives/160GB+-+600GB/500GB+Western+Digital+Caviar+Blue+WD5000AAKX+3.5%22+SATA+III+Hard+Drive+-+HDD+?productId=43780
Operating system: I think I'll just grab an OEM version of windows 7 off Amazon
In total, it will cost £557.07.
Also, what do you think to the system in general, could it play crysis/metro 2033 at high settings?
Thanks in advance.
Thanks in advance.
