Hey guys,
Right now im running ESXI 5.1 and i seem to be having performance problems. First i will list my specs then I will list my problems.
Specs:
AMD Phenom II x4 965 Black Edition
ASRock 960GM/U3S3 FX AM3+
16GB 1600Mhz DDR3 Ram
1TB drive 7200RPM as data store
Rest of drives are mapped to a VM which i will explain lower
2x3TB WD Green Drives
2x2TB WD Drives
1x2.5TB Drive
Software Setup:
3VMS
1 Windows 7 64 bit just for playing on when im at work or just want to do something overnight without leaving desktop on
1 Windows 7 64 bit for Plex and Utorrent
1 Windows Server 2012 Essentials for AD/Web interface/and all the other goodies
On the Windows Server 2012 Essentials I have a software called Drive Bender which allows me to take all my extra drives and pool them together and present them as one. Its very useful.
Now onto the problem
I seem to have performance issues with this computer. When i login to the windows 7 machine it lags alot and I feel it should run alot smoother. Now theres a part i left out. The configureation of all of them. I set them all to have 4GB ram which with 16GB ram shouldnt be a problem. BUT the cpu I set them all to have 4 cores. I did this because a buddy of mine was telling me that ESXI is smart enough to distribute the power evenly but i feel like maybe he was wrong and that was the problem. What do you guys think?
Solutions:
I was thinking about upgrading my processor to one of the 8Core processors since i always have an AM3+ motherboard. ORRR I was thinking about buying an Intel i5 Processor with a new motherboard that support 32GB ram. This same friend told me that the I5 outperformes the 8core processors any day. Let me know what you think please.
Specs:
2x2TB WD Drives
1x2.5TB Drive
Software Setup:
3VMS
Solutions:
