Help please, not starting properly
SebDrewett
22
the motherboard green light is on, when booted the fans run for 5/6 seconds, its then stops for a few seconds and starts again.
There is no image when connected to a moniter.
I had to take off the heat sink for 2/4 of the ram sticks so the cpu cooler fits, but after testing each ram slot with one ram stick the problem is still the same
I had to be a little rough with the motherboard when fitting it in the micro atx case but there was no serious pressure.
When apply the processor I had to use alot of force and when pushing down it made some noise but I'm certain it was lined up
so far.. http://s3.postimage.org/v131n2kxv/P1010200.jpg
All the components (new)
Installed
Vengeance DDR3 4 x 4 GB (16GB)
Intel i7-3770k
Asus P8Z77-M Pro
LiteOn IHOS104 4x SATA Internal BD-ROM
Fractal Design Core 1000 Series Micro ATX
ANKWE USB 3.0 front panel
OCZ ModXStream Pro Series 600W ATX
Noctua NH-U9B SE2 Socket 775
1xAkasa Viper High Performance S-Flow 12cm
Gelid Solutions Silent 9 Quiet
Not yet installed
840 series Samsung 250GB
Sandisk SATA III 128GB
MSIHD7950 Twin Frozr AMD/ATI - 3GB
tripledouce
465
Too bad you dont have a motherboard with the error LED's it would tell you where POST is erroring. since you are not getting any beep codes i would say this is a power issue make sure all your connectors are seated properly if they are you may want to test your ATX connector for the proper voltages.
