Multiple exploding power supplies! Please help!
- New Build
Power Supplies
- Games
Systems
Last response: in Systems
calpol55
February 14, 2013 1:04:34 PM
Hi! I've built a pc for my friend so he can play games on it, but everytime he goes to play a game on it, his power supply explodes! When I built it, me and my friend was playing games on it for hours at my house, and it was working perfectly, but when he takes it round to his house, he plays a game and the power supply explodes! This has happened 3 times now!
Here's his specs:
i5 2320
P8H61-LX
8GB XMS3 Corsair RAM
500GB hard drive
Asus GTX 560 Ti 2GB
Alpine 700w power sully (I know it's terrible!)
We have tried 3 different power supplies (all same model) but all of them have exploded at his house, but not at mine! Could it be that there is something wrong with his plug sockets or something? Also, if he buys a Corsair CX500 power supply, would this one explode? Thanks
Here's his specs:
i5 2320
P8H61-LX
500GB hard drive
Asus GTX 560 Ti 2GB
More about : multiple exploding power supplies
SHORYUKEN
February 14, 2013 1:09:16 PM
calpol55 said:
Hi! I've built a pc for my friend so he can play games on it, but everytime he goes to play a game on it, his power supply explodes! When I built it, me and my friend was playing games on it for hours at my house, and it was working perfectly, but when he takes it round to his house, he plays a game and the power supply explodes! This has happened 3 times now! Here's his specs:
i5 2320
P8H61-LX
500GB hard drive
Asus GTX 560 Ti 2GB
May be something to do with his sockets. This seems like a rude question, but is his house dirty? Do you think he has leakage that may result in water in the socket? And what do you mean by "explodes"? Like literally blows up into a fiery wreckage? Or just get burnt and it can't be used?
- installing power supplies psu antec neo eco 620 help please - Forum
- OMG FIRE SMOKE EXPLODING POWER SUPPLIES!!! - Forum
- please help me choose one of these power supplies - Forum
- Question about power supplies concerning multiple 12v rails. - Forum
- Is my Power Supply/MoBo going bad, please help - Forum
diellur
February 14, 2013 1:16:01 PM
Generic PSUs aren't the best, but they definitely shouldn't do that. And absolutely not 3 times in a row...the issues isn't the PC, it's the electrics at the house.
Seriously, there's a chance of someone dying if the electrics are dodgy at the house, he needs to get that sorted out. Like, yesterday.
calpol55
February 14, 2013 1:23:07 PM
I would start by checking the polarity of the AC receptacle your plugging into with something like the following(can get these cheap testers at Lowes, Home Depot, newegg etc):
http://www.amazon.com/gp/product/B002LZTKIA/ref=pd_lpo_...
calpol55
February 14, 2013 1:24:28 PM
SHORYUKEN said:
May be something to do with his sockets. This seems like a rude question, but is his house dirty? Do you think he has leakage that may result in water in the socket? And what do you mean by "explodes"? Like literally blows up into a fiery wreckage? Or just get burnt and it can't be used?His house isn't really dirty, and the power supplies make a loud bang with a shower of blue sparks coming out of the back of it
Country
For US.
First check the Oulet fo Proper Wiring.
Very simple, go to Lowes or Home depot and buy a cheap tester.
This will verify proper polarity, Ie hot, common nd ground.
You plug it in and read the lights.
Question Is he using an UPS. If so Some UPS have a really bad Output AC waveform that can damage some Computer power supplies.
Simple check is to plug System directly into wall outlet - AFTER doing # 1 above.
For " dirty Power" need expensive equipment , ie an O'scope. So better left to a tech to verify house wiring.
For US.
SHORYUKEN
February 14, 2013 1:26:12 PM
calpol55
February 14, 2013 1:27:12 PM
calpol55
February 14, 2013 1:28:17 PM
SHORYUKEN
February 14, 2013 1:29:55 PM
calpol55
February 14, 2013 1:33:19 PM
ilysaml said:
Quality PSUs have SCP (Short Circuit Protection), OVP (Over Voltage Protection), UVP, & OCP...all these will function if he has something wrong with the power socket.Also it may be related to the input voltage, cheap garbage PSUs don't operate @220V
Get Corsair TX 650W
So if we get a TX 650, if something goes wrong again, will those protections stop the power supply from exploding? Also, will I be able to continue using the computer afterwards or would the power supply be broken?
calpol55
February 14, 2013 1:34:00 PM
In the UK you obviously need a different mains tester but you can find them cheap. I suspect the house has a wiring issue which for many electronics isn't a noticeable issue.
http://www.amazon.co.uk/Green-Mains-Socket-Safety-Teste...
calpol55 said:
So if we get a TX 650, if something goes wrong again, will those protections stop the power supply from exploding? Also, will I be able to continue using the computer afterwards or would the power supply be broken?No it wouldn't harm the PSU neither the components, the PC won't operate or will shut down immediately if anything occurs.
calpol55
February 14, 2013 1:43:08 PM
JamesSneed said:
In the UK you obviously need a different mains tester but you can find them cheap. I suspect the house has a wiring issue which for many electronics isn't a noticeable issue.http://www.amazon.co.uk/Green-Mains-Socket-Safety-Teste...
I'm going to buy one of those and if it comes up with any faults, I'll tell the electrician. Thanks for all the replies everyone!
diellur
February 14, 2013 1:47:22 PM
calpol55
February 14, 2013 1:53:12 PM
I haven't no, only the one plug socket, I've also had it plugged into a 4-way surge protection adapter, this one: http://www.argos.co.uk/static/Product/partNumber/901702...
A better model of surge protector will also indicate correct/incorrect wiring normlly.
A cheap Voltmeter (Very simple to use) will also verify polarity. Left or right prong will be 220->240. when measured o the ground prong. The other one should read zero (although most will show 1 to 2 volts). Need to verify which side should be Hot
calpol55
February 14, 2013 2:15:19 PM
RetiredChief said:
A better model of surge protector will also indicate correct/incorrect wiring normlly.A cheap Voltmeter (Very simple to use) will also verify polarity. Left or right prong will be 220->240. when measured o the ground prong. The other one should read zero (although most will show 1 to 2 volts). Need to verify which side should be Hot
Awesome, I'll get that checked out too
calpol55
April 5, 2013 10:41:48 AM
So it took a while, but I've finally got an electrician out to check the plugs. He said that the plugs are working perfectly, absolutely nothing wrong with it, now I'm confused! What else could be exploding my power supplies?! Could it be temperature? Because I've heard that cheap power supplies can only go up to something like 30C or something, that seems a bit low doesn't it?
calpol55
April 6, 2013 7:55:30 AM
diellur
April 6, 2013 1:08:14 PM
calpol55
April 6, 2013 4:28:00 PM
diellur said:
The only thing it could be is that you've been unlucky with generic PSUs. Your system probably sucks down about 300-400W on load, and a generic PSU may not be able to provide that, hence fails. A branded PSU won't have that issue.Ah thank you ^_^ I'm getting an XFX 550w power supply for it anyways
ARICH5
April 6, 2013 6:08:04 PM
diellur
April 7, 2013 2:00:59 AM
- Power Supply exploded...HELP Forum
- SolvedPlease help me choose power supply Forum
- SolvedHelp on power supply please Forum
- SolvedCorsair 800GS power supply acting up, please help! Forum
- I think my power supplies broken help please fast Forum
- Power Supplies for the GTX280 in SLI, help please! Forum
- SolvedMy Power supply is making a clicking noise please help! Forum
- SolvedPlease help me choose a power supply Forum
- SolvedWill My Power Supply Run AMD 7970?????!!!!! Please Help Forum
- Solvedevga 680 classified in sli 750w power supply please help Forum
- SolvedPower supply issue due to new graphics card. Please help Forum
- SolvedPower supply issue. Please help Forum
- SolvedI dont know what power supply i need. please help?! Forum
- SolvedPower Supply Help Please?!! Forum
- SolvedPower Supply Help Please !!! Forum
- More resources
