First PC build, do these parts fit together?
Last response: in Systems
Hello, this is my first build, do these parts fit together and is the PSU good enough? Please respond fast. Thanks in advance.
PowerColor Radeon HD 7770 1GB GDDR5
PCI-Express 3.0, DL-DVI-I, native-HDMI, DisplayPort
MSI B75MA-P45, Socket-1155
m-ATX, B75, DDR3, 1xG3-PCIe-x16, SATA 6Gb/s, USB 3.0, VGA, DVI, UEFI
Intel® Core i3-3220 Processor
Socket-LGA1155, Dual Core, 3.3GHz, 3MB, 55W, HD2500, Boxed w/fan
Silver Power SP-SS500 500W PSU
ATX 12V V2.2, 80 Plus, Standard, 1x 6pin+1x 6+2pin PCIe, 6× SATA, 3x Molex
Kingston DDR3 HyperX 1600MHz 8GB
Kit w/2X HyperX 4GB DDR3, CL9-9-9-27, 240pin
Corsair Carbide 200R Midi Tower Svart
Fläktar: 1x 140mm Front, 1x 120mm Bak, ATX, mATX, 2x USB 3.0
More about : build parts fit
no, these parts are a bit wrong
for PSU, find one from XFX/corsair 450-550W
for RAM, that kingston is 1,65v ram. make sure you get 1,5v for intel :)  can be corsair/gskill
Related ressources
What about;
Corsair Vengeance DDR3 1600MHz 8GB
1x8GB 9-9-9-24 1,5V 240 pins Quad Channel
XFX ProSeries Core Edition V2 450W PSU
ATX 12V V2.31, 80 Plus Bronze, Standard, 1x 6+2pin PCIe, 6x SATA, 3x Molex
Would these work?
dontfeed said:
What about;
Would these work?
Those would be better, you might want to get 550W just to be on the safe side.
Noob12 said:
kingston has 1.5 and 1.65V and 1.8V memory kits.
kingston hyper x blue series. http://www.kingston.com/en/memory/hyperx/blu
So.. Intel says that for ivybridge memory can be 1.5V +-5% that is 1.575 V
I think that 1.65V is 10% more. maybe B-75 is not good for that voltage but good Z-77 MoBo is going to bee fine with 1.65V memory. If cpu is cooler properly.
Eny good cpu or MoBo is not going to break down with 10% over volt usage.
This is too 1.5-1.65V memory.
http://www.kingston.com/en/memory/hyperx/predator/beast
I didn't fully understand what you wrote, but did you mean i should get a z77 motherboard instead? Is this one good?
Gigabyte GA-Z77M-D3H, Socket-1155
m-ATX, Z77, DDR3, 1xG3+1xG2-PCIe-x16, CFX, VGA, DVI, HDMI, UEFI
Noob12 said:
Take dual channel to 1155 set . quad is for 2011 set
It didn't say if this one was dual channel, would you know if it is? It's the same price as the previous,
Corsair Vengeance DDR3 1600MHz 8GB CL9
Kit w/2x 4GB XMS3 modules, CL9-9-9-24, 1.5V, Vengeance Heatspreader, 240
