First final build - looking for last adjustments!
Hello all, I have 2 builds right now I'm choosing from:
http://pcpartpicker.com/p/DwS7
http://pcpartpicker.com/p/DBjF
Pretty sure obviously the second is better, but I was wondering if I could do some cut backs(or not), just not letting the price go above the $940 build.
EDIT: Seen a build on a previous thread on this forum, http://pcpartpicker.com/p/DBdw
Wouldn't be using the wireless adapter or monitor, so there is definitely room for upgrades!
15 answers Last reply
More about first final build adjustments
  1. I wouldn't get a 450w to power up an OCed i5-3570k and a 7950.
    That's just asking for trouble. Get at least 500~550 watts.
  2. what are some things i should downgrade then? I can't go over this budget really. Would it be a better idea to just get a build with the 660ti?
  3. Hi, i like your first build, made some changes in it :
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($223.79 @ Amazon)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($129.99 @ Microcenter)
    Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($39.99 @ Newegg)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($75.98 @ SuperBiiz)
    Video Card: Sapphire Radeon HD 7950 3GB Video Card ($295.66 @ Newegg)
    Case: NZXT Source 220 ATX Mid Tower Case ($49.99 @ Amazon)
    Power Supply: Rosewill Hive 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($69.99 @ Amazon)
    Optical Drive: Samsung SH-224BB DVD/CD Writer ($17.99 @ Newegg)
    Total: $933.37
  4. Getting the Antec Neo Eco 520 or Rosewill Green 530 or XFX 550w would be better.
    More or less, they are cheaper or the same than the one you picked.
    XFX 550w would be the best.
  5. How about:
    Motherboard: ASRock Z77 Pro4 ATX LGA1155 Motherboard ($109.99 @ Amazon)
    Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($39.98 @ Outlet PC)
    Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($71.68 @ Outlet PC)
    Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($49.99 @ Newegg)
    Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ Outlet PC)
    Total: $891.05
    (Generated by PCPartPicker 2013-02-14 21:53 EST-0500)
    Total: $933.37
    Everyone agree that this is the best I could probably get for my budget?
  7. Nope. You get a free 8gb ram kit if you get the z77 Extreme4 at newegg right now. So that's what I would buy now.
  8. Hi, the psu is modular, and it's a good one : http://www.hardwaresecrets.com/article/Rosewill-HIVE-650-W-Power-Supply-Review/1460/11
    It's a decent one for crossfire if he wants to :)
    The ram that comes with it is single channel with different cas times than the cheaper ones, he might get in trouble when adding another one, mix and matching ram isn't good.
    What's this mean? Should I take out current RAM in the build if the combo comes with a free 8gb?
  10. Yes. Buy the Asrock z77 Extreme4 @ Newegg NAO!
    FREE RAM!!! yes. You save money too!
  11. Hi, get the asrock extreme 4 in newegg, it's just 5$ more, pcpartpicker picks microcenter, but it has shipping costs, the default should be either amazon or newegg.
    Stay with the ram or sell it afterwards.
  12. so keep the Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory? seems like im getting mixed messages here lmao. Wouldn't be very easy to sell it around where I live if I were to purchase it.
  13. Hi, you can stay with single channel, it will not affect the performance, but dual channel is faster, you can get another stick of the vengeance and get the total of 16GB dual channel, you can stay with one stick, or get the crucial ram and sell that stick.
    Plenty of options there :)
  14. Gahhh. Get the Free 8gb ram and just don't buy one.
    Ram is ram. It's going to be either 1333mhz or 1600mhz so you really won't notice any difference.
  15. okay thanks a lot guys!
Build Wireless Adapter Monitors Systems Product
