Guys,
Recently i reset my front case fan, then i plug the front panel back(not the cable to be plug at the mobo)
i turn on my pc from the switch button at the case,
somehow nothing happen,
i able to turn on the pc from the mobo onboard switch button, but not from the case switch
i think i might touch something the time i reset the front fan
do i currently have a dead front switch(so as the reset switch)?
i open the front panel back and check if there any unplug wire etc.. everything seem normal to me
does a new case will solve this?
is there any aftermarket switch button? i seen one in a build log, but i dont really remember it
*im using z77 Mpower board
*an old case
just unrelated question, what happen if someone plug the front panel connecter wrongly to the mobo?
*an old case
