C CallmeTomPlease Honorable Dec 29, 2012 3 0 10,510 Dec 30, 2012 #1 I have a ECS A960M-M3 AM3+ AMD 760G Micro ATX AMD Motherboard and I'm wondering if I can put a 660 GTX graphics card in it. Thank you in advance.
Solution J J johnsonjohnson Dec 30, 2012 Hi. Yes you can since it has a PCI Express X16 slot. Make sure you have a quality power supply with enough power and cables for your system.
J johnsonjohnson Honorable Dec 15, 2012 779 0 11,160 Dec 30, 2012 Solution #2 Hi. Yes you can since it has a PCI Express X16 slot. Make sure you have a quality power supply with enough power and cables for your system. Upvote 0 Downvote Solution
C CallmeTomPlease Honorable Dec 29, 2012 3 0 10,510 Dec 30, 2012 #3 Best answer selected by CallmeTomPlease. Upvote 0 Downvote
C CallmeTomPlease Honorable Dec 29, 2012 3 0 10,510 Dec 30, 2012 #4 Thank you johnsonjohnson I appreciate it. Upvote 0 Downvote
J johnsonjohnson Honorable Dec 15, 2012 779 0 11,160 Dec 30, 2012 #5 You're welcome! Don't forget that the graphics card will need power from the PCI-E cable. Upvote 0 Downvote
