Ok so here is the scenario. I recently biult a computer and have the xfx 7850 Graphic card in it. It It has two dvi ports one supports analog conversion to VGA. so i bought an adapter and hooked it up to my tv but no signal.
I have the computer preferences set up for two monitors. When i unplug the vga from my tv and plug it into a old monitor i have it works fine. I have a Vizio e-series 42 inch tv. But it just keeps saying no signal.
I know the adapter and chord are fine because i tested it on the old monitor i had in my closet. I have the old monitor sitting by my tv and i had it all set up for dual monitors using the old monitor. I unplug it from the old monitor and plug it directly into the tv a couple feet away and no signal.
What would be the reason for this? As of right now i am on my good computer monitor, it is set at desktop 2, and i can see desktop 1 (my tv) just still says no signal on my tv.
I have completely run out of ideas, if you guys can give me any thing to try here i would appreciate it.
