New gaming pc build want to see if all these parts are compatible
- Homebuilt
Systems
- Product
Last response: in Systems
baddane
February 15, 2013 6:10:26 PM
I'm finally getting around to putting together a PC from scratch and could use some advise. More precisely I actually need someone to check over my build primarily to ensure that all components are compatible with one another. here are the spec
motherboard=ASUS M5A97 AMD 9 Series AM3+ Motherboard - ATX, Socket AM3+, AMD 970 Chipset, 2133MHz DDR3 (O.C.), SATA 6.0 Gb/s, 8-CH Audio, Gigabit LAN, SuperSpeed USB 3.0, CrossFireX Ready (tigerdirect.com)
cpu=AMD FD6200FRGUBOX FX-6200 Processor - Six Core, 8MB L3 Cache, 6MB L2 Cache, 3.80GHz (4.10GHz Max Turbo), Socket AM3+, 125W, Fan, Unlocked, Retail (tigerdirect.com)
ram=Patriot Viper 3 Intel Extreme Masters PVI38G186C9K 8GB Limited Edition Memory Kit - 2 x 4GB, PC3-15000, 1866MHz, 9-10-9-27, 1.5V (tigerdirect.com)
cpu cooler=Corsair Hydro Series H55 Quiet Edition Liquid CPU Cooler (CW-9060010-WW)(amazon.com)
video card=MSI R7770-2PMD1GD5/OC Radeon HD 7770 Video Card - 1024MB, GDDR5, PCI-Express 3.0 (x16), 1x DVI, 2x Mini DisplayPort, 1x HDMI, DirectX 11, Dual-Slot, CrossFireX Ready, Eyefinity, Overclocked (tigerdirect.com)
ssd=ADATA USA Premier Pro 2.5-Inch 128GB SATA III MLC Internal Solid State Drive ASP900S3-128GM-C (amazon.com)
hhd=WD Blue WD10EZEX 1TB Desktop Hard Drive - 3.5", SATA, 7200RPM, 64MB Cache (tigerdirect.com)
power supply=Coolmax ZU Series ZU-800B 800W Power Supply - 140mm Fan, 80PLUS Bronze, ATX, Modular, Active PFC, NVIDIA SLI or ATI CrossFire (tigerdirect.com)
case=Apevia X-Trooper Mid Tower Case w/ Blue LED (amazon.com)
this computer is gonna be mostly use for mmorpg games for maxx setting to thanks
More about : gaming build parts compatible
flamehead269
February 15, 2013 6:29:41 PM
Um, the links to these products would be nice, because the info used to see if the parts are compatible aren't all there, but, I would recommend a better GPU and only get the cooler if you plan to overclock, the processor and the motherboard will go together, and I'm not exactly sure about the RAM and the Motherboard working but I'm pretty sure, if you could suppply tthe links to these parts, I could tell you more.
m
l
MauveCloud
February 15, 2013 6:32:50 PM
That's a bad choice of psu. According to http://www.eggxpert.com/forums/thread/323050.aspx CoolMax psus other than the CTG series are dangerous.
m
l
- New pc build, i want have parts checked out for compatibility issues. - Forum
- im building a pc and i want to know are all the parts im my build are build are compatible? - Forum
- New user looking to build a gaming PC. Are these parts compatible? - Forum
- Building a custom pc, i want to know if my parts are compatible????? - Forum
- £550 Gaming PC Build - Are the parts compatible and how good are they? - Forum
baddane
February 15, 2013 6:47:14 PM
ok sorry about the link here they are
video card=http://www.tigerdirect.com/applications/SearchTools/ite...
motherboard=http://www.tigerdirect.com/applications/SearchTools/ite...
cpu=http://www.tigerdirect.com/applications/SearchTools/ite...
ram=http://www.tigerdirect.com/applications/SearchTools/ite...
power supply=http://www.tigerdirect.com/applications/SearchTools/ite...
hhd=http://www.tigerdirect.com/applications/SearchTools/ite...
ssd=http://www.amazon.com/gp/product/B007RHT48S/ref=ox_sc_a...
tower=http://www.amazon.com/gp/product/B0051QMSNA/ref=ox_sc_a...
cpu cooler=http://www.amazon.com/gp/product/B009VV56TY/ref=ox_sc_a...
m
l
flamehead269
February 15, 2013 6:49:26 PM
flamehead269
February 15, 2013 6:53:23 PM
baddane
February 15, 2013 6:56:37 PM
baddane
February 15, 2013 7:26:26 PM
flamehead269
February 15, 2013 7:31:23 PM
baddane
February 15, 2013 7:32:57 PM
flamehead269
February 15, 2013 7:51:26 PM
-.- you put in a 800 watt, which really isnt need at all for your build, I'd go down.
But really, that GPU is just horrible I would go with this:
m
l
baddane
February 15, 2013 8:41:55 PM
baddane
February 15, 2013 9:02:48 PM
baddane
February 15, 2013 9:05:21 PM
baddane said:
do u think 650 watts is good650 is definitely plenty for your needs.
Quote:
is that power color company any good never heard of them They're fine.
You do not want to purchase that case or power supply - both from horrible brands. I wouldn't touch either one with a 10 foot pole. The liquid cooler is unnecessary and I think I would skip the SSD for now and invest in a better video card.
This would be a better setup for your budget:
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($214.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Newegg)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($119.99 @ Newegg)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($52.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($295.66 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case ($92.98 @ Newegg)
Power Supply: Corsair Builder 600W 80 PLUS Certified ATX12V Power Supply ($49.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($21.98 @ Newegg)
Total: $943.56
(Generated by PCPartPicker 2013-02-15 18:22 EST-0500)
m
l
baddane
February 15, 2013 9:25:11 PM
found another power supply http://www.tigerdirect.com/applications/SearchTools/ite...
m
l
baddane
February 15, 2013 9:27:10 PM
baddane said:
found another power supply http://www.tigerdirect.com/applications/SearchTools/ite...Huh, I didn't know they made a modular version. Good to know.
This is better and cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
wolfkraut
February 15, 2013 9:54:58 PM
g-unit1111 said:
650 is definitely plenty for your needs.Quote:
Total: $943.56
This^ These parts are SO much better than what you selected. No offense, but what you had was a medium settings build for an ultra price, this is high-ultra settings for a fitting price. However, I think you could save a few bucks on the RAM, but it's hard to say as prices have been all over the place lately. Also, the PSU is good, but if you have the money, a nice SeaSonic, XFX or Corsair PSU would be better. I've heard about issues with the Builder series, but then again, this may be a new revision. One last thing, do you live near a Micro Center?
m
l
patrick47018
February 15, 2013 10:06:48 PM
I'd go with this power supply definitely over the one you wanted to get
m
l
Traciatim
February 15, 2013 10:32:16 PM
g-unit1111 said:
You do not want to purchase that case or power supply - both from horrible brands. I wouldn't touch either one with a 10 foot pole. The liquid cooler is unnecessary and I think I would skip the SSD for now and invest in a better video card. This would be a better setup for your budget:
Total: $943.56
So much of this. This would completely destroy the original machine.
m
l
baddane
February 16, 2013 4:48:09 AM
Traciatim
February 16, 2013 12:30:47 PM
baddane
February 16, 2013 12:39:29 PM
Traciatim
February 16, 2013 1:04:46 PM
baddane said:
is there a big different between intel and amd game performance ?http://www.anandtech.com/bench/Product/697?vs=701&i=505...
Intel 3570k peaks at a smidgen over 40% faster than the 8350 . . . so depending on the game, yes. Even though it's running at 3.4Ghz instead of 4.0Ghz for the AMD the Intel pretty much destroys it... and they both overclock well.
There are certain things the AMD will be good at... but for gaming machines you want an Intel Ivy/Sandy bridge these days until something new comes out it isn't going to change.
m
l
baddane
February 16, 2013 1:09:55 PM
Traciatim
February 16, 2013 1:34:54 PM
baddane said:
ok thanks man what can u tell me about window 7 or window 8 which is better for gamingI haven't seen many benchmarks that really show that huge of a difference, it's really more of a personal preference. You can read about it right here on Toms over at http://www.tomshardware.com/reviews/windows-8-gaming-pe...
If you don't want to bother going through it, There was really no difference between the two that you would notice, except for in one game there was a problem running it on Win8, but since the review was from October I'm sure they've fixed that by now.
m
l
baddane
February 16, 2013 1:45:01 PM
Traciatim said:
I haven't seen many benchmarks that really show that huge of a difference, it's really more of a personal preference. You can read about it right here on Toms over at http://www.tomshardware.com/reviews/windows-8-gaming-pe... If you don't want to bother going through it, There was really no difference between the two that you would notice, except for in one game there was a problem running it on Win8, but since the review was from October I'm sure they've fixed that by now.
Yeah one OS or another won't make a huge difference in how your build performs. Metro I can take it or leave it but the desktop on Windows 8 is business as usual. I'm told there's apps that can manipulate the start screen to be like Windows 7 but I haven't pursued any of them.
m
l
- SolvedMy first mid range gaming desktop build, just wanted to check with everyone to see if it's good enough/compatible. Forum
- SolvedNew gaming pc. Need help knowing if parts are compatible with each other Forum
- SolvedNew to PC building Are these parts compatible? Forum
- SolvedGuys am from india i want to build a decent gaming pc.i have choosen some parts like cpu,gpu etc for it.plz help me are those Forum
- SolvedAre all these parts compatible for my gaming pc build? Forum
- SolvedWant to build gaming pc just for league of legends, I have no Idea what parts I will need. Forum
- [Build Help] I Want To See If It's Possible To Upgrade My PC To An Equivalent Low End Gaming Build Forum
- SolvedSo I am looking to build a pc for gaming and I want to know how well the parts I chose will work. My price range is about 1300 Forum
- SolvedWhat parts should I buy if I want to build a gaming pc for under 500 Bucks. Ill be running an hdmi monitor and some pretty int Forum
- SolvedHome Built Gaming PC, Going to upgrade it but want to use old parts to build budget PC for (11yr old son) Forum
- SolvedBuilding a gaming PC, need help/advice if chosen parts are compatible Forum
- SolvedI want to use some old parts to build a new pc Forum
- SolvedI really want to build a gaming pc for minecraft and mods... can anyone give me there view of parts required? ny budget is aro Forum
- SolvedWant to build new inexpensive gaming rig, already have some parts ($400, $500, $600 or so) Forum
- SolvedI want to be able to keep up with newer games, do I need new parts, or a new PC? (HP Pavilion Media Center TV m8125x PC) Forum
- More resources
