6670 power supply confusion...
I have a Nav tech PSU, details are as below,
Model- ATX 500T 20+4 Pin
AC INPUT- 220V3A 50 Hz
Fuse Rating-F5A 250V
DC OUTPUT- MAX 500W
+3.3V/14 amp..... +5V/20 Amp......+12V/10 Amp....... -12V/0.5 Amp ........+5VSB/2 Amp........
I would like to know how much ampere is available on +12 volt rail and shall i be able to run Readon HD 6670 1GB DDR3 ????
pls dont mind if i have asked a dumb question..as i am preety newb in these matters.
iam2thecrowe said:
what else is in the computer? cpu? how many hdds? IMO the 10 amps on the 12v rail is not enough for much at all, a low power cpu, motherboard and 1 hard drive. get another psu.
I have one WD Gren sata 7200 RPM 1TB HDD, AMD Phenom X4 9550 2.2 Ghz processor and 1 DVD RW drive and 1 MSI K9N2GM motherboard.i guess it is a basic motherboard...nothing else.
Related ressources
Power supply Expert
Sakkura said:
Looks like it could be an (old) ATX 1.x PSU. Also, they're lying bastards. 500W? Not even close. You'll need a new PSU.
Yea... No matter how creative I get I can't get above about 260W. Ballsy even for a PSU maker. If that Web address is navtech.org it goes to a mobile phone maker lol.
Even if you don't upgrade the GPU I would STRONGLY recommend replacing the PSU ASAP
