CUSTOM PC BUILD - NEED URGENT HELP
Info:Im looking to buy a computer for my graphic design work though I will also be using it for gaming, I am on quiet a tight budget and I live in Australia but I am able to buy online. It will need to be able to run Black Ops 2 on reasonably high settings and will have to run smoothly whilst running a screen capture [Camtasia] and Photoshop. I will not be doing any extreme video work other than rendering 2-5 minute videos from Sony Vegas Pro. I need to know what parts I should get and what is recommended for my needs!
Approximate Purchase Date: Next month
Budget Range: $600-$1,000 AUD
System Usage from Most to Least Important: Photoshop work, Screen-recording, Gaming, Video rendering.
Are you buying a monitor: No.
Do you need to buy OS: No.
Preferred Website(s) for Parts: MSY [www.MSY.com.au], BCC [www.BCCComputers.com.au], PCCG [www.pccasegear.com], Any others AU or Online
Parts Preferences: Intel processor, anything else is I have no preference on.
Overclocking: None.
SLI or Crossfire: None.
Your Monitor Resolution: 1680 x 1050 http://www.asus.com/Monitors_Projectors/VW222U/
Additional Comments: I will mainly be using Photoshop whilst running Camtasia. I will mostly be playing COD Black Ops 2, League of legends, ect.
Why Are You Upgrading: Need an upgrade for graphic design work and gaming.
Thanks In Advance,
-Max
8 answers Last reply
More about custom build urgent help
  1. pccasegear is an easier site to work with
  2. My suggestion :
    CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor ($239.00 @ PCCaseGear)
    Motherboard: ASRock H77M Micro ATX LGA1155 Motherboard ($79.00 @ PCCaseGear)
    Memory: Corsair Vengeance LP 16GB (2 x 8GB) DDR3-1600 Memory ($99.00 @ PCCaseGear)
    Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($75.00 @ PCCaseGear)
    Storage: Plextor M5S Series 128GB 2.5" Solid State Disk ($119.00 @ PCCaseGear)
    Video Card: PowerColor Radeon HD 7870 XT 2GB Video Card ($229.00 @ PCCaseGear)
    Case: Cooler Master Elite 430 ATX Mid Tower Case ($49.00 @ PCCaseGear)
    Power Supply: Antec EarthWatts Green 650W 80 PLUS Bronze Certified ATX12V Power Supply ($89.00 @ PCCaseGear)
    Optical Drive: Samsung SH-224BB DVD/CD Writer ($22.00 @ PCCaseGear)
    Total: $1000.00
    Since the 7850 2GB is almost at the same price as the 7870 tahiti le, i think it's worth getting the 7870 for just ~10$ more, this includes the intel xeon 1230 v2 which is an i7 without the on die gpu.
  3. No reason to purchase a Xeon for a gaming rig (I'll shoot down that suggestion every time, fair warning) , and the Elite 430 is a very poor choice on a $1K build. For Photoshop if you feel it's worth it to get the i7 then definitely.
    This is what I would suggest:
    CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($229.00 @ PCCaseGear)
    CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($35.00 @ PCCaseGear)
    Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($135.00 @ PCCaseGear)
    Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($54.00 @ Foxcomp)
    Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($59.00 @ PCCaseGear)
    Case: Antec One ATX Mid Tower Case ($65.00 @ PCCaseGear)
    Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($115.00 @ PCCaseGear)
    Total: $943.00
    (Generated by PCPartPicker 2013-02-16 10:40 EST+1100)
    If you're not planning to overclock:
    CPU: Intel Core i7-3770 3.4GHz Quad-Core Processor ($295.00 @ PCCaseGear)
    Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($95.00 @ PCCaseGear)
    Total: $979.00
    (Generated by PCPartPicker 2013-02-16 10:44 EST+1100)
  4. Image Product Description Unit Price Savings Total Price
    Update
    Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm ...
    Model #:CHALLENGER
    Item #:N82E16811147153
    Return Policy:Standard Return Policy
    In Stock
    Note (Add)
    $59.99 -$10.00 Instant $49.99
    Update
    GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    Model #:GA-Z77X-UD3H
    Item #:N82E16813128544
    In Stock
    Note (Add)
    $169.99 -$20.00 Instant $149.99
    Update
    EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
    Model #:02G-P4-2662-KR
    Item #:N82E16814130826
    Return Policy:VGA Standard Return Policy
    In Stock
    Mail in Rebate Card
    Note (Add)
    $229.99 $229.99
    Update
    CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC ...
    Model #:CP-9020031-NA
    Item #:N82E16817139010
    In Stock
    Note (Add)
    $169.99 -$30.00 Instant $139.99
    Update
    Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
    Model #:BX80637I53570K
    Item #:N82E16819116504
    Return Policy:CPU Replacement Only Return Policy
    In Stock
    Note (Add)
    $229.99 $229.99
    Update
    G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
    Model #:F3-12800CL9D-8GBXL
    Item #:N82E16820231428
    Return Policy:Memory Standard Return Policy
    In Stock
    Note (Add)
    $49.99 $49.99
    Update
    Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Model #:WD1002FAEX
    Item #:N82E16822136533
    In Stock
    Note (Add)
    $104.99 $104.99
    Update
    ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
    Model #:DRW-24B1ST/BLK/B/AS
    Item #:N82E16827135204
    In Stock
    Note (Add)
    $19.99 $19.99
    Update
    Microsoft Windows 7 Home Premium SP1 64-bit - OEM
    Model #:GFC-02050
    Item #:N82E16832116986
    Return Policy:Software Standard Return Policy
    In Stock
    Note (Add)
    $99.99 $99.99
    Subtotal: $1,074.91
    Select All - Select None
    Update
    Model #:CHALLENGER
    In Stock
    Note (Add)
    Links to Newegg won't work in Australia, where the OP is from.
  6. djangoringo said:
    My suggestion :
    Total: $1000.00
    OP said Photoshop>gaming so this rig is perfect.
    You still don't need a Xeon. It's a server processor and isn't really meant to handle consumer / gaming applications.
  8. No reason to purchase a Xeon for a gaming rig (I'll shoot down that suggestion every time, fair warning) , and the Elite 430 is a very poor choice on a $1K build. For Photoshop if you feel it's worth it to get the i7 then definitely.
    The xeon is worth the cost, since it's for editing, the xeon is as good as the i7, but without the on die gpu,it's perfectly compatible, since it will have a discrete card, it will do.
    It can handle all applications as good as the i7-3770, with it, there's room for a ssd.
    The elite 430 is a good case for the price, there's nothing wrong with it, it's not one of those flimsy cases, it's a good case for its price.
Homebuilt Systems
