Case: Rosewill FBM-01 Dual Fans MicroATX Mini Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147123
CD/DVD Drive: SAMSUNG DVD Burner SATA Model SH-224BB - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151256
Hard Drive: TOSHIBA DT01ACA050 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822149380
Motherboard: ECS A780LM-M2 AM3 AMD 760G Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135315
Wireless Adapter: Rosewill RNWD-N1501UB IEEE 802.11b/g/n, USB2.0 Wireless-N Mini Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166079
Graphics Card: SAPPHIRE Radeon HD 5450 1GB 64-bit DDR3 PCI Express 2.1 x16 HDCP Ready Low Profile Ready Video Card ( 100292DDR3L)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102882
Power Supply: LOGISYS Computer PS350MA 350W Micro ATX Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817170015
Memory: Team Elite 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model TED34096M1333C9DC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313102
CPU: AMD Athlon II X2 270 Regor 3.4GHz Socket AM3 65W Dual-Core Desktop Processor ADX270OCGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103953
Power Cable: Coboc 6 ft. Power Cable with 3 Conductor PC power (Black)
http://www.newegg.com/Product/Product.aspx?Item=N82E16812117273
__________________________________
So, does this look like it could handle streaming media and light gaming? My current computer is an 08 Macbook with 2.4ghz core 2 duo, so if this computer beats that, I'm happy.
Questions:
1) Are there ANY incompatibilities between the parts? Will everything fit nicely together and function? Is there a slot in the motherboard for everything? Etc.
2) Would I be better off (financially mostly) with getting an internal wireless network card or sticking with the adapter?
3) Is my power supply sufficient?
4) Are the fans in the case sufficient?
5) Will I be able to put a Windows install disk in the DVD drive after I've completely assembled the computer and install and run Windows? Or does my hard drive have to have it preinstalled?
Thanks again, hope you guys can help!
Questions:
