I just received all my components from NewEgg and started assembling them. I got everything installed and pressed the power button to observe a single quick beep and the power shutting down in about half a second. So I started removing parts. I removed everything except CPU, motherboard and PSU. I found that when I remove the 8 pin CPU power connector, the system boots. When it is connected, it beeps once and turns off.
Does this mean I have a bad CPU or a bad PSU? I'm going to see if I can borrow a PSU from a friend to try but I have a feeling it's not the PSU.
Asrock P67 Fatality Performance Motherboard
Core i5-3570K CPU
Corsair CX600 PSU
Thanks in advance for any suggestions.
-Jake
Core i5-3570K CPU
Corsair CX600 PSU
-Jake
