Solved
HD 5770 Struggling Fallout New Vegas
Hey Guys,
I have had some pretty severe video lag out of my ATI cards the last two weeks. I have uninstalled and reinstalled, using driver sweeper. Ran the system file checker; nothing. Ran defrag and error checking; nothing. Even cleaned and replaced the thermal pads on the GPUs; nothing. I have tried the beta back through four past drivers on the ATI site. the best it has done is when the Catalyst Control Center was uninstalled. I'm even benching with an old game because I thought these cards were outdated for the new stuff. Nope 7FPS in New Vegas. I have included a screen shot of HWM and the settings for the game, CCC.
11 answers Last reply Best Answer
More about 5770 struggling fallout vegas
  1. The gpu is old ok but u r mobo and processor can handle that card.
    so give full system configuration.
  2. Best answer
    Update windows .Automatically detect and install latest best driver and fix all issues.
    Update bios.
    Update hdd/ssd firmware.
    Update Gpu firmware .
    Full Scan system with "SUPERANTISPYWARE" Freeware.
    Not cure problems change cmos battery.
  3. I just wanted to jump in here and give you some second thought items instead of more whining:
    1. The character sounds in FO3 are not playing, nor is the dialog.
    2. I uninstalled and re-installed all my .net framework.
    3. re-installed directX 11
    4. re-installed MS Visual C++
    5. re-installed Steam with the game in question.
    6. re-installed MS Silverlight
    7. re-installed Java-64
    8. returned ATI-CCC to factory defaults; 2-6 FPS on the same game settings in the picture and 10-12 at "low" games settings.
    9. Ate a chicken burrito; made me feel better but did not help my frame rate or sound issue.
  4. Adjust your game settings to achieve a high minimum framerate.
    If you wish to run VSync, your frames should never drop below 60.
    (When they do, they drop to 30.)
    You are running 1920x1080, 4x AA, VSync enabled.
    You are showing the O/C page from CCC.
    That's not what I want to see - what about the 3D settings?
    Set everything to High Performance, or application-controlled.
    Adjust your in-game settings for high framerate. No AA. No VSync.
    No need to O/C either your vidcard or CPU!
    Dumb it down until you're getting great performance, with eye-candy turned off.
    Many are happy with 30FPS average; I require 60FPS minimum.
    Let me turn you on to a great (free) benchmark: the S.T.A.L.K.E.R. Call of Pripyat benchmark!
    (One of my favourite games.)
    See what is required for you to achieve 60 FPS minimums.
    I personally was shocked - DX9 and Medium preset, no AA, no candy for me...
    Check it out, it's a fantastic benchmark. Hours of fun, and a real eye-opener.
    7FPS is pretty brutal though, heheh... maybe you have a situation?
    You've removed and cleaned-out your vidcard's cooler and fan?
    Good luck and let us know what happens,
    Regards
  5. Hytecgowthaman,
    Ok man, I'll give it a shot and post the results.
    Thanks for the speedy reply,
    Raj
  6. OGS,
    3d Application Settings:
    Anti-Alising = use application settings
    Antisotropic Filtering = Use application Settings
    Tessellation = AMD Optimized
    Catalyst A.I. = surfice format optimization enabled & set to performance
    Mipmap Detail level = performance
    Anti- Ailasing Mode = performance
    OpenGL Settings = tripple buffering
    AMD Crossfire enabled & set to default mode
    these were the settings while running my tests. As far as I can tell it's as low as it will go.
    I'm going to start on that firmware stuff and I'll be back
    thanks,
    Raj
  7. ------------------
    System Information
    Time of this report: 12/30/2012, 22:36:03
    Machine name: NYX
    Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120830-0333)
    Language: English (Regional Setting: English)
    System Manufacturer: OEM
    System Model: OEM
    BIOS: Phoenix - AwardBIOS v6.00PG
    Processor: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz (8 CPUs), ~3.2GHz
    Memory: 6144MB RAM
    Available OS Memory: 6136MB RAM
    Page File: 3001MB used, 9266MB available
    Windows Dir: C:\Windows
    DirectX Version: DirectX 11
    DX Setup Parameters: Not found
    User DPI Setting: Using System DPI
    System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
    DxDiag Version: 6.01.7601.17514 64bit Unicode
    DxDiag Notes
    Display Tab 1: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
    Sound Tab 1: No problems found.
    Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (retail)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: ATI Radeon HD 5800 Series
    Manufacturer: Advanced Micro Devices, Inc.
    Chip type: AMD Radeon Graphics Processor (0x6898)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_6898&SUBSYS_032E1043&REV_00
    Display Memory: 725 MB
    Dedicated Memory: 2009 MB
    Shared Memory: 2811 MB
    Current Mode: 1920 x 1080 (32 bit) (60Hz)
    Monitor Name: SyncMaster PX2370 /PX23720Plus (Digital)
    Monitor Model: SyncMaster
    Monitor Id: SAM0656
    Native Mode: 1920 x 1080(p) (60.000Hz)
    Output Type: DVI
    Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
    Driver File Version: 8.17.0010.1169 (English)
    Driver Version: 9.10.8.0
    DDI Version: 11
    Driver Model: WDDM 1.1
    Driver Attributes: Final Retail
    Driver Date/Size: 12/2/2012 01:48:52, 1137664 bytes
    WHQL Logo'd: No
    WHQL Date Stamp: None
    Device Identifier: {D7B71EE2-2BD8-11CF-6277-2423BEC2C535}
    Vendor ID: 0x1002
    Device ID: 0x6898
    SubSys ID: 0x032E1043
    Revision ID: 0x0000
    Driver Strong Name: oem33.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Evergreen:9.10.8.0:pci\ven_1002&dev_6898
    Rank Of Driver: 00E62001
    Video Accel: ModeMPEG2_A ModeMPEG2_C
    Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
    D3D9 Overlay: Not Supported
    DXVA-HD: Not Supported
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    Sound Devices
    Description: Speakers (High Definition Audio Device)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0889&SUBSYS_10DE0175&REV_1000
    Manufacturer ID: 1
    Product ID: 65535
    Type: WDM
    Driver Name: HdAudio.sys
    Driver Version: 6.01.7601.17514 (English)
    WHQL Logo'd: Yes
    Date and Size: 11/20/2010 04:44:23, 350208 bytes
    Other Files:
    Driver Provider: Microsoft
    HW Accel Level: Basic
    Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    Description: Microphone (High Definition Audio Device)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x1
    Format Flags: 0xFFFFF
    Description: Digital Audio (S/PDIF) (High Definition Audio Device)
    Default Sound Capture: No
    Default Voice Capture: No
    Cap Flags: 0x1
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Device Name: G9x Laser Mouse
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC066
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Device Name: G13
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC21C
    FF Driver: n/a
    Device Name: G15 Gaming Keyboard
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC226
    FF Driver: n/a
    Attached: 1
    Controller ID: 0x0
    FF Driver: n/a
    Device Name: G15 GamePanel LCD
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC227
    FF Driver: n/a
    Device Name: Logitech G13 Joystick
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC2AB
    FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x3A34
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/24/2011 21:29:26, 343040 bytes
    | Driver: usbd.sys, 3/24/2011 21:28:59, 7936 bytes
    Gameport Devices
    PS/2 Devices
    + HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    | Driver: kbdhid.sys, 11/20/2010 04:33:25, 33280 bytes
    | Driver: kbdclass.sys, 7/13/2009 19:48:04, 50768 bytes
    | Service: kbdhid
    | Service: kbdhid
    | Vendor/Product ID: 0x046D, 0xC232
    | Service: kbdhid
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: i8042prt.sys, 7/13/2009 17:19:57, 105472 bytes
    + Logitech HID-compliant G9x Laser Mouse
    | Matching Device ID: hid\vid_046d&pid_c066&mi_00
    | Upper Filters: LMouFilt
    | Lower Filters: LHidFilt
    | Service: mouhid
    | Driver: LHidFilt.Sys, 6/17/2009 08:54:22, 55312 bytes
    | Driver: LMouFilt.Sys, 6/17/2009 08:54:30, 57872 bytes
    | Driver: KHALMNPR.Exe, 6/17/2009 08:53:28, 130576 bytes
    | Driver: mouhid.sys, 7/13/2009 18:00:20, 31232 bytes
    | Driver: mouclass.sys, 7/13/2009 19:48:27, 49216 bytes
    | Driver: WdfCoInstaller01005.dll, 11/2/2006 08:04:56, 1919968 bytes
    + HID-compliant mouse
    | Vendor/Product ID: 0x046D, 0xC231
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 11/20/2010 07:33:57, 63360 bytes
    | Driver: sermouse.sys, 7/13/2009 18:00:20, 26624 bytes
    Disk & DVD/CD-ROM Drives
    Drive: A:
    Free Space: 81.6 GB
    Total Space: 114.3 GB
    File System: NTFS
    Model: INTEL SSDSC2MH120A2 ATA Device
    Drive: C:
    Free Space: 85.3 GB
    Total Space: 152.5 GB
    File System: NTFS
    Model: INTEL SSDSA2M160G2GC ATA Device
    Drive: E:
    Free Space: 652.4 GB
    Total Space: 1430.8 GB
    File System: NTFS
    Model: ST31500341AS ATA Device
    Drive: F:
    Free Space: 214.2 GB
    Total Space: 259.2 GB
    File System: NTFS
    Model: WDC WD3200BEVT-22ZCT0 ATA Device
    Drive: G:
    Free Space: 29.7 GB
    Total Space: 31.1 GB
    File System: NTFS
    Drive: D:
    Model: Optiarc DVD RW AD-7240S ATA Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 03:19:21, 147456 bytes
    System Devices
    Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
    Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_3A3C8086&REV_00\3&2411E6FE&1&D7
    Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:04, 52736 bytes
    Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:14, 325120 bytes
    Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:26, 343040 bytes
    Name: Intel(R) ICH10 Family SMBus Controller - 3A30
    Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_3A308086&REV_00\3&2411E6FE&1&FB
    Driver: n/a
    Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
    Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_00008086&REV_13\3&2411E6FE&1&38
    Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 07:33:48, 184704 bytes
    Name: High Definition Audio Controller
    Device ID: PCI\VEN_1002&DEV_AA50&SUBSYS_AA501043&REV_00\4&13A6E568&0&0118
    Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 04:43:43, 122368 bytes
    Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
    Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_3A3A8086&REV_00\3&2411E6FE&1&EF
    Name: Intel(R) ICH10 Family 6 Port SATA AHCI Controller - 3A22
    Device ID: PCI\VEN_8086&DEV_3A22&SUBSYS_3A208086&REV_00\3&2411E6FE&1&FA
    Driver: C:\Windows\system32\DRIVERS\msahci.sys, 6.01.7601.17514 (English), 11/20/2010 07:33:44, 31104 bytes
    Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 19:45:46, 48720 bytes
    Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 19:52:21, 24128 bytes
    Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 07:32:46, 155520 bytes
    Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
    Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_00008086&REV_13\3&2411E6FE&1&18
    Name: ATI Radeon HD 5800 Series
    Device ID: PCI\VEN_1002&DEV_6898&SUBSYS_032E1043&REV_00\4&3908E232&0&0038
    Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1278 (English), 12/2/2012 02:29:48, 11270656 bytes
    Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 12/2/2012 01:14:28, 53248 bytes
    Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6290 (English), 12/2/2012 01:13:20, 546816 bytes
    Driver: C:\Windows\system32\atiumd64.dll, 9.14.0010.0942 (English), 12/2/2012 01:24:50, 6781440 bytes
    Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0381 (English), 12/2/2012 01:41:44, 4674048 bytes
    Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0023 (English), 12/2/2012 01:35:26, 120320 bytes
    Driver: C:\Windows\system32\atiicdxx.dat, 9/18/2012 08:00:40, 662787 bytes
    Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 12/2/2012 01:17:54, 56320 bytes
    Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 12/2/2012 01:17:54, 56320 bytes
    Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1124 (English), 12/2/2012 01:14:10, 619008 bytes
    Driver: C:\Windows\system32\atiumd6a.cap, 12/2/2012 01:38:16, 3053056 bytes
    Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 12/2/2012 01:35:10, 21504 bytes
    Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 12/2/2012 02:00:18, 163840 bytes
    Driver: C:\Windows\system32\ativvsva.dat, 12/2/2012 01:38:16, 157144 bytes
    Driver: C:\Windows\system32\ativvsvl.dat, 12/2/2012 01:38:16, 204952 bytes
    Driver: C:\Windows\system32\ativvaxy_cik.dat, 9/4/2012 09:20:18, 228528 bytes
    Driver: C:\Windows\system32\ativvaxy_cik_nd.dat, 9/4/2012 09:20:18, 228528 bytes
    Driver: C:\Windows\system32\ativce02.dat, 9/19/2012 13:09:40, 76660 bytes
    Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1137 (English), 12/2/2012 01:36:50, 240640 bytes
    Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1137 (English), 12/2/2012 01:37:36, 548864 bytes
    Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 12/2/2012 01:35:04, 59392 bytes
    Driver: C:\Windows\system32\atidemgy.dll, 4.00.4719.4733 (English), 12/2/2012 01:37:46, 442368 bytes
    Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.11995 (English), 12/2/2012 02:17:12, 23455744 bytes
    Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.1741 (English), 12/2/2012 01:58:44, 51200 bytes
    Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.1741 (English), 12/2/2012 01:58:36, 44544 bytes
    Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.1741 (English), 12/2/2012 01:58:24, 16082944 bytes
    Driver: C:\Windows\system32\atipblag.dat, 9/12/2011 16:06:16, 3917 bytes
    Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6290 (English), 12/2/2012 01:11:14, 104448 bytes
    Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6290 (English), 12/2/2012 01:11:28, 130048 bytes
    Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6290 (English), 12/2/2012 01:13:44, 17920 bytes
    Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6290 (English), 12/2/2012 01:13:38, 41984 bytes
    Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 15:35:28, 118784 bytes
    Driver: C:\Windows\system32\atiapfxx.blb, 12/2/2012 02:03:22, 320136 bytes
    Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0470 (English), 12/2/2012 01:29:04, 7378944 bytes
    Driver: C:\Windows\SysWOW64\atiumdag.dll, 9.14.0010.0942 (English), 12/2/2012 02:31:34, 5626536 bytes
    Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0381 (English), 12/2/2012 01:29:30, 3862528 bytes
    Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 12/2/2012 01:17:44, 56832 bytes
    Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 12/2/2012 01:17:44, 56832 bytes
    Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1124 (English), 12/2/2012 01:14:00, 421888 bytes
    Driver: C:\Windows\SysWOW64\atiumdva.cap, 12/2/2012 01:27:50, 3084672 bytes
    Driver: C:\Windows\SysWOW64\ativvsva.dat, 12/2/2012 01:38:16, 157144 bytes
    Driver: C:\Windows\SysWOW64\ativvsvl.dat, 12/2/2012 01:38:16, 204952 bytes
    Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 12/2/2012 01:35:00, 43520 bytes
    Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.11995 (English), 12/2/2012 01:57:54, 18979328 bytes
    Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0470 (English), 12/2/2012 01:46:46, 6684672 bytes
    Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.1741 (English), 12/2/2012 01:58:42, 46080 bytes
    Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.1741 (English), 12/2/2012 01:58:34, 44032 bytes
    Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.1741 (English), 12/2/2012 01:54:08, 13703168 bytes
    Driver: C:\Windows\SysWOW64\atipblag.dat, 9/12/2011 16:06:16, 3917 bytes
    Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6290 (English), 12/2/2012 01:11:04, 83968 bytes
    Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6290 (English), 12/2/2012 01:11:20, 109568 bytes
    Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6290 (English), 12/2/2012 01:13:30, 33280 bytes
    Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6290 (English), 12/2/2012 01:13:42, 14848 bytes
    Driver: C:\Windows\SysWOW64\atiapfxx.blb, 12/2/2012 02:03:22, 320136 bytes
    Driver: C:\Windows\atiogl.xml, 11/13/2012 13:11:14, 42310 bytes
    Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 09:34:36, 51200 bytes
    Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 12:33:08, 332800 bytes
    Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6290 (English), 12/2/2012 01:13:42, 14848 bytes
    Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1169 (English), 12/2/2012 01:48:52, 1137664 bytes
    Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1169 (English), 12/2/2012 01:50:46, 949248 bytes
    Driver: C:\Windows\system32\coinst_9.01.8.dll, 1.00.0004.0008 (English), 12/2/2012 01:59:56, 70144 bytes
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
    Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_3A398086&REV_00\3&2411E6FE&1&D2
    Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 3/24/2011 21:29:03, 30720 bytes
    Name: Intel(R) ICH10R LPC Interface Controller - 3A16
    Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_3A168086&REV_00\3&2411E6FE&1&F8
    Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 19:48:27, 15424 bytes
    Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
    Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_00008086&REV_13\3&2411E6FE&1&08
    Device ID: PCI\VEN_1002&DEV_6898&SUBSYS_032E1043&REV_00\4&13A6E568&0&0018
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
    Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_3A388086&REV_00\3&2411E6FE&1&D1
    Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
    Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_13\3&2411E6FE&1&A3
    Driver: n/a
    Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
    Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_100D3842&REV_13\3&2411E6FE&1&00
    Driver: n/a
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
    Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_3A378086&REV_00\3&2411E6FE&1&D0
    Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
    Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&2411E6FE&1&A0
    Driver: n/a
    Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_90\3&2411E6FE&1&F0
    Name: Intel(R) ICH10 Family PCI Express Root Port 3 - 3A44
    Device ID: PCI\VEN_8086&DEV_3A44&SUBSYS_3A448086&REV_00\3&2411E6FE&1&E2
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
    Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_3A368086&REV_00\3&2411E6FE&1&EA
    Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
    Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&2411E6FE&1&A2
    Driver: n/a
    Name: Realtek PCIe GBE Family Controller
    Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_816810EC&REV_03\4&12FF54F6&0&00E2
    Driver: n/a
    Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
    Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_3A408086&REV_00\3&2411E6FE&1&E0
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
    Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_3A358086&REV_00\3&2411E6FE&1&E9
    Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
    Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&2411E6FE&1&A1
    Driver: n/a
    Name: Texas Instruments 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_00000000&REV_00\4&1EDC1F61&0&18F0
    Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/20/2010 04:44:56, 229888 bytes
    Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_3A3E8086&REV_00\3&2411E6FE&1&D8
    Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
    Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_3A348086&REV_00\3&2411E6FE&1&E8
    Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 9 - 3410
    Device ID: PCI\VEN_8086&DEV_3410&SUBSYS_00008086&REV_13\3&2411E6FE&1&48
    Device ID: PCI\VEN_1002&DEV_AA50&SUBSYS_AA501043&REV_00\4&3908E232&0&0138
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
    ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,12.05.0000.21202
    ATI MPEG Video Decoder,0x00200000,1,2,atimpenc64.dll,12.05.0000.21202
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
    ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,12.05.0000.21202
    AMD MJPEG Decoder,0x00800001,1,1,atimpenc64.dll,12.05.0000.21202
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Line 21 Decoder,0x00600000,1,1,,
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
    ATI MPEG Video Encoder,0x00200000,1,1,atimpenc64.dll,12.05.0000.21202
    DivX Decoder Filter,0x00800000,1,1,DivXDec.ax,7.01.0001.0014
    ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,12.05.0000.21202
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
    File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
    ATI Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,12.05.0000.21202
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
    Overlay Mixer2,0x00200000,1,1,,
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
    Overlay Mixer,0x00200000,0,0,,
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
    ATI Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,12.05.0000.21202
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
    GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
    Audio Capture Sources:
    Microphone (High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
    Digital Audio (S/PDIF) (High De,0x00200000,0,0,qcap.dll,6.06.7601.17514
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
    WDM Streaming Capture Devices:
    HD Audio Mixed capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    HD Audio Digital in,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    WDM Streaming Rendering Devices:
    HD Audio HDMI out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    HD Audio Headphone/Speakers,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
    Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7601.17713
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
    DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
    EVR Power Information
    Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
    Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
    Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
    PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
  8. Hytecgowthaman,
    did all that but couldn't find a firmware update for the HD 5770s.
    my problems persist.
    MFW sad slow GPUs
    Raj
  9. Btw before you change your CMOS battery it's good if you know how to set up your bios. I'm learning right now lol.
    Also you may have noticed that I'm dealing with a set of HD5870s and not HD 5770s my bad guys.
    Raj
  10. Sorry for the delay there I had to go out of town for a bit.
    Ok, here is what the issue was. The CMOS battery was dying. Once that happened the voltage settings for the RAM and CPU were out of sync along with the hard drive settings [ACHI] allowing for the SSDs to operate.
    I found that information for the RAM voltage in this post: http://www.tomshardware.com/forum/302568-31-manually-setting-speed-timings-voltage.
  11. Best answer selected by rajrentfro.
Radeon Graphics
